Unread 01-13-2020, 09:49 AM   #31
brandonw
took a bit due to the holidays and vacation but the floor is built. Plumbing it to the walls, making sure it was level and square was a chore and I was covered in mortar. Had to elevate the kerdi tray 1" to sink in the drain
Brandon
Thanks for helping me! If you need any computer advice/help or digital security help just ask.
brandonw is offline   Reply With Quote
Unread 01-13-2020, 02:11 PM   #32
speed51133
how did you elevate the tray 1in????
speed51133 is online now   Reply With Quote
Unread 01-13-2020, 06:29 PM   #33
I don't know how he did it, but Schluter recommends just adding in another layer of foam the required thickness, sandwiched in with thinset to bond it all together. You'd want to make sure you got some that was dense enough.
Unread 01-14-2020, 11:16 AM   #34
brandonw
I used dense polythene which I''ll link to below. They say just use a polyethylene sheet but after I went any bought just any sheet I didn't like how pliable it was. I went back and bought the stuff below. This stuff below is very dense and rigid just like the schluter stuff. I also used it to fill in the missing piece of the schluter tray then mortared on top of it using a straight edge to keep the same pitch as the tray.
Also, I ignored the trowel guide and tossed a ton of mortar on the floor and on the 1" ploy layer then walked all around it for about 5 minutes. I had 100% coverage and it was so much easier than scraping, lifting the tray, adding more here adding more there blah blah blah. It used about 2.5g of pretty wet mortar
https://www.homedepot.com/p/Project-...-PP1/203553730
Brandon
Unread 01-14-2020, 11:36 AM   #35
speed51133
Polystyrene. Polyethylene like a cutting board.
You should have trowelled it on as required in the instructions. That mortar is not intended to be built up thick. You also want to ensure even coverage to keep the slope proper. Did you put a level on multiple spots of the tray to ensure the slope is still ok??
Unread 01-16-2020, 05:54 AM   #36
brandonw
yes I leveled everything time and time again. I rechecked after it cured and the curb wound up about 1/16th of an inch out of plumb at 2ft up on both sides. Guess the mortar shrunk some. I can make that up when I tile but overall it's perfect. The instructions say I can keep going but it's been 48hrs and I still see dark mortar that isn't fully cured. I need to finish the floor and seams but was worried about the not fully cured areas. Can I keep going?
Brandon
Unread 01-16-2020, 08:14 AM   #37
speed51133
not only will thick globs of mortar take a while to cure, but yet, they will shrink and also can crack easily. It is not meant to be built up like that.
Unread 01-16-2020, 09:36 AM   #38
brandonw
it's the mortar towards the drain and in the edges that gooped up. I'll let it cure another day or two to be safe.
Brandon
custom levelquick over custom peel and stick membrane Big Joe Tile Forum/Advice Board 7 12-15-2012 10:17 AM
Custom Shower - Need some confirmation on bisazza shower install MyFirstShower Tile Forum/Advice Board 17 12-13-2009 09:06 PM
I think I butchered the install... Edthedawg Tile Forum/Advice Board 21 07-04-2009 04:37 PM
Custom Building Products Custom Blend CharlesW Tile Forum/Advice Board 15 02-20-2009 11:51 AM
My first custom shower annieef Tile Forum/Advice Board 5 09-26-2003 01:25 PM
