Unread 01-16-2020, 11:28 PM   #16
You accidentally damaged the flange? The flange is usually buried behind the finished tile. Is the damage going to be visible after tiling?
Unread 01-16-2020, 11:42 PM   #17
tman1991
Yeah it got stuck all at a weird angle and it was hard to get out. Had to be there but it basically stated to crush in the flange from being pushed against a stud. It was suspended in the air in the alcove and one end got under the ledger board for the flange. It was interesting. Anyways unless the crack grows you wont see it. Its like 3/4 of the flange but that will be hidden
Travis
tman1991 is offline   Reply With Quote
Unread 01-17-2020, 12:06 AM   #18
Ah...yes. One of the bigger difficulties in setting a tub is manipulating it from a standing position down into its final horizontal position without getting it stuck at weird angles.
Yes, cement board is often stopped just above the tiling flange as you describe. But sometimes folks will shim out the back 5’ wall and sometimes the ‘wet’ wall and ‘far’ wall, as well (unless doing so creates a weird jog in the wall), then run the cement board down over the tiling flange to just shy of the tub’s shoulder.
What method of waterproofing are you planning? Perhaps plastic behind the cement board? Or a surface applied roll-on membrane to the front of the cement board such as RedGard or Hydroban? Or....?
And you might want to think about removing a bit more drywall. The first inch or two of the wall where it meets the tub apron is a very common location for moisture damage. Cement board and tile in these locations does a lot to prevent moisture damage. But maybe I should ask if you’re planning to use a shower curtain...or a shower door?
Unread 01-17-2020, 12:22 AM   #19
tman1991
Same as the shower I just did. Durock membrane over durock. And I dont plan on shimmying anything as that would create weird jogs I think. Also only going up about 5 feet above tu lb as that's were the old one stopped. Not going to ceiling.
I was just going to tile the outside of the tub area using bullnose. Just attach it to drywall and use a shower curtain. Thats what was there currently. I guess I could cut our the drywall and run a strip of durock and accomplish the same thing?
Travis
Unread 01-17-2020, 12:41 AM   #20
D & D Reno
That is a bummer about the crack. You did say it would cover, but if you aren’t sure you could shim out that wall behind the Duroc just a touch if
you think it may be close.
Antonio
D & D Reno is offline   Reply With Quote
Unread 01-17-2020, 12:46 AM   #21
tman1991
Yeah I could try to shim it some to lower the durock but if I have tile that goes down to just over the deck and that is essentially buried in thinset what's the difference?
Travis
Unread 01-17-2020, 07:22 PM   #22
Your studs look to be 24 inches OC. I would add some studs or at least some horizontal blocking to give you more to nail/screw to.
Unread 01-17-2020, 07:50 PM   #23
tman1991
Yeah they are and that's being looked at. Going to put up durock next and will certainly add more if I need them. Especially after my last bathroom and adding some behind the other wall which was a giant mess.
Travis
Unread 01-18-2020, 06:41 AM   #24
Pull the installation sheet for Durock, Travis, pretty sure it calls for studs 16" OC. If you don't have those you do need to add them. Like Davy said, you can add horizontal 2X's to accomplish this.
Tiling on/inside Bathtub question isshounoyakusoku Tile Forum/Advice Board 4 06-09-2014 10:56 PM
Bathtub edge tiling question: oldberkeley Tile Forum/Advice Board 6 12-29-2013 10:43 PM
Quick question....tiling next to bathtub... jasonc Tile Forum/Advice Board 13 04-16-2010 10:37 AM
Tiling around a bathtub Mbdornbush Tile Forum/Advice Board 4 04-22-2006 06:25 PM
easy bathtub enclosure tiling question Jeff Kolinski Tile Forum/Advice Board 5 07-03-2004 01:23 PM
