Unread 11-14-2019, 02:50 PM   #16
MobileMarch567
Yeah, I was afraid that might be the issue...
To start over, should I trash the current pan liner & scrape off as much silicone as I can, then just re-do the liner placement with a new liner & fresh silicone?
Bill
MobileMarch567 is offline   Reply With Quote
Unread 11-14-2019, 04:25 PM   #17
Shouldn't need to replace the liner unless you think you may have damaged it in the installation/removal processes, Bill. Lifting it off the drain, ensuring it's clean around the drain portion on the bottom, ensuring the bottom drain flange is also clean, and reinstalling it properly might work out OK.
The guy who was there for the installation and removal would be the best guy to evaluate the potential for re-use versus replacement, eh?
Unread 12-30-2019, 08:51 AM   #18
MobileMarch567
shower mud is crumbly!
Good morning all! I finished my shower mud and its been drying for the past 48 hours. However, it crumbles and breaks apart in several places if I press down on it with my finger. Other parts feel much more solid.
My plan was to vacuum/sweep up the loose parts, then replace them with more mud. The fresh mud will mostly likely be less than 1.5" thick, but it will be on top of the existing mud, so the total thickness of new mud + old mud will be minimum 1.5"
Would this work ok?
(in the pic, ignore the wet section in the lower left, i just spilled some water)
Bill
Unread 12-30-2019, 09:16 AM   #19
You should be fine as long as its well bonded. You're looking for compressive strength. Not sheer strength
Unread 12-31-2019, 12:12 PM   #20
MobileMarch567
Update-Thank you!
I scrapped off as much of the mud as I could and attached a pic with the result...I think its obvious where I packed it down best, lol...could I still put fresh mud over this? Its about 1" thick at the deepest 'valleys'
Bill
Unread 12-31-2019, 09:34 PM   #21
Bill, for that top mud bed you really wanna remove it all and start over. That type of shower receptor construction is designed for the mud bed to be consistently porous and uniform in thickness to function properly. Trying to bond new mud to old using thinset mortar will disrupt that.
I'd also very strongly recommend you divest yourself of those plastic divider strips in your top mud bed. You can get away with nearly anything in the pre-slope, but you don't need any plastic strips in your final mud to tell the mud or/and tile surface where to crack or separate. And those plastic strips prevent you from having the consistent thickness from drain to perimeter of a minimum of 1 1/2" of mud as required by tile industry standards. They're a bad idea whose time has long passed.
Unread 01-06-2020, 11:54 AM   #22
MobileMarch567
Still getting "crumbly deck mud", what am I doing wrong?
Thanks everyone for your replies!
I took out all the old deck mud, removed the plastic "shower pitch" pieces, re-did it using the Quikrete Sand/Topping Mix + all purpose sand (1 bag sand/topping mix to half bag sand) with an emphasis on really packing it down well. I used a 4" wood block, a 12" float, a 14" float, a finishing trowel, and my bare hands.
Frustratingly, I still got crumbling, though not as bad as last time. What could be going wrong? Am I not adding enough water?
I'm tempted to use something with lime in it, like a type S mortar, just to solve this problem, and pack it down with a garden hoe.
Any advice? My pic show what it looks like after I vacuumed up the loose excess. Thank you!
Bill
Unread 01-06-2020, 01:21 PM   #23
HS345
Tile Contractor
HS345's Avatar
You might be mixing it too dry, or you may be getting bad bags of sand topping mix. In my area I only have a couple of stores where I trust the bags. Look for stores that store them inside, and bags that aren't faded. Did you notice any hard chunks in the bags?
The name's Greg
Unread 01-06-2020, 01:34 PM   #24
Bill, you do not want a Type S mortar mix for that top mud bed. Unlike the pre-slope, the top mud bed has a specific design purpose of good compressive strength while still being porous enough to allow water to pass easily through it.
If your mud bed is not uniform in its texture (I can't tell from the photo) and it is vacuuming up in some places and not others, I would look at insufficient dry mixing of the components before adding water as a possible part of the problem.
I have, as a result of many, many visitor's complaints about their deck mud, tried to duplicate the problem a number of times. Sometimes when placing an actual shower bed, other times just as a test, and I have not been able to duplicate the problem. I decided at one point that it must be inadequate compaction of the mud before shaping as that is the only thing I wouldn't try on an actual project because without that you're just not placing deck mud. But I tried too little or too much cement, too little water, wrong type of sand, (that will cause some problems), different methods of mixing, and whatever else I could think of. I'd still get usable deck mud.
I wish I knew just what to tell you, but I don't.
How long are you letting this mud cure before you start vacuuming?
Are you covering it with polyethylene sheeting while you allow it to cure?
Are you dry-mixing to a very uniform consistency before adding water?
How long are you working the mix from the time you first add water 'till the time you finish placing the mud?
Unread 01-06-2020, 04:43 PM   #25
MobileMarch567
Cx - thanks (as always!) for your reply.
FYI, my bed is not uniform in color or density; it varies from light grey to dark grey & from rock-hard to crumbly. You're saying I should spend more time mixing before adding the water?
To your questions:
I let the mud cure 24 hours before touching it at all. I don't cover it with any sheeting or anything. I try my best to add the sand to the dry mix, then mix it, then add water, then mix it to a consistent, dark, damp uniformity before packing it.
I don't measure the exact water amount but I keep adding small amounts until I can squeeze a "snowball" in my hand and it keeps its shape.
After adding the water, I take about 10 minutes to mix & work it with a shovel and a metal rake. I load it up into a bucket, then pack it all around the edges of the shower, using a laser level & a 2foot long 2x4 and a rubber mallet to pack it down level around all four edges. Then I pack it into the drain area, then i simply connect the inner and outer rings with the rest of the mortar. I didn't use a finishing trowel, just packed and packed and packed, until my knees and back were on fire. Then I sprayed the top with a fine mist from a windex spray bottle. Then I take a bunch of ibuprofen....thats it!
A few other things I thought of: Quikrete recommends replacing half the water with acrylic fortifier....Also, I could leave OUT the extra sand and JUST use the "Sand/topping mix". Also, Measure EXACTLY the amount of water as recommended by Quikrete?
Sorry to go into so much detail, but I hoped that might help you figure out what's going wrong...
Bill
Unread 01-06-2020, 07:26 PM   #26
If I had to guess, I'd say you're mixing it a little too dry. That doesn't mean you want it to be soupy. I'd leave the spray mist off of it. If you get enough water in the mix, it doesn't need it. Sometimes that will wash the cement down away from the surface, leaving the surface sandy. When you get the mud shaped like you want, slick it down with a flat steel trowel. That should put a slight shine on the surface which will make the surface harder.
Oh, and you don't have to pack the crap out of it. Give it a couple slaps, move over 4-5 inches and repeat. Adding the plastic like Cx said is good advice although I've never done it on a shower floor in 40+ years. I want it to set so I can tile it the next day.
Unread 01-06-2020, 07:44 PM   #27
And Davy knows that the plastic does not slow the curing of the mud at all, he just doesn't wanna do it.
He's right about the packing of the mud, though. You don't hafta try to beat it into submission, and you don't need to be able to walk on it without leaving footprints when you're done packing, you just need to make it firm before cutting to shape.
It sounds to me like your mixing is at least part of the problem if your mud doesn't look uniform in color and texture when placing it.
And I agree with Dave about not spraying the placed mud with water. It takes very, very little moisture to cause the cement in the mixture to begin the process of hydration. And when I have experimentally mixed my mud too dry to the point where I was sure this time there was no way it was gonna work, it set up just fine if given enough time.
You might wanna get you a Bucket Mortar Mixer for the next time you're fixin' to do a small mud job. You can dry mix all your materials in five gallon buckets and stage them near the work area. It then takes only 1 or 2 minutes of mixing with your water to make another batch. Very handy tool for those of us who usually work alone. I sometimes wonder how I ever got along without one.
Unread 01-13-2020, 12:43 PM   #28
tile_n00b
I had a similar issue when I did the preslope on my shower. I did the 5:1 mix, started with the border around the edge, packed in the middle, let it dry, and ended up with a bunch of sandy/crumbly spots. I was able to remove chunks of it with a shop vac just like your situation.
I had much better results on my second attempt (and with the top layer of mud above the liner) by using a 4:1 mix instead of 5:1 and using a bit more water. I also skipped doing the edge first and just worked my way around in a circle, alternating sides to prevent having a cold joint. Check here for photos and details: https://www.johnbridge.com/vbulletin...d.php?t=119864
Ryan
tile_n00b is offline   Reply With Quote
Unread 01-27-2020, 09:16 AM   #29
MobileMarch567
Thank you everyone; got rid of crumbles!
Just wanted to update on the crumbly mortar: I took the crumbly mix out completely, started over and this time it was much, much better!
For other people that might have the same problem, here's what I did different:
I used the Mapei 4-to-1 mud bed mix (as opposed to Quikrete Sand Topping mix) and I mixed all of it at once and dumped in into the pan (as opposed to building the outer edges and working my way in). I also did NOT add any additional water at the end or spray it down or anything. I EXACTLY measured the amount of water to mix (as opposed to mixing water 'until i could form a clump in my hand'). I did NOT use the "perfect slope" plastic pieces, either...I just drew a line all around the liner and used that as my highest point for the mud.
Thanks again, everyone that offered advice; I really appreciate it.
Bill
Concrete shower floor - barrier free - linear floor drain wcontractors Tile Forum/Advice Board 4 08-15-2017 12:32 PM
Installing shower drain in concrete floor USAF JB Tile Forum/Advice Board 2 05-31-2014 10:26 AM
drain is flush with concrete sub floor solemn Tile Forum/Advice Board 4 12-12-2009 10:40 AM
HELP Please. Shower drain isn't flush with tile. Allen279 Tile Forum/Advice Board 5 06-11-2009 10:39 PM
Shower Drain in Concrete Floor newgene Tile Forum/Advice Board 11 09-27-2006 03:36 PM
