Unread 01-15-2020, 08:55 PM   #151
Lucy_Dawg
About to caulk the corners with silicone caulk, and am wondering thedifference between these two caulks. I will be caulking inside corners and floor to wall transitions. One caulk has a sanded texture, and looks a lot better, but I am afraid to use it for this situation. Advice on which to use is appreciated. Thank you!
https://www.homedepot.com/p/Custom-B...610S/204984830
or
https://www.homedepot.com/p/Custom-B...C386/202753965
Paul
Lucy_Dawg is offline   Reply With Quote
Unread 01-15-2020, 09:14 PM   #152
The one with the sanded texture is not a 100 percent silicone sealant and is not really suitable for your application.
The one that is 100 percent silicone I have not used, but suspect it is a glossy finish and I'd not want to use it in my new shower, 'specially if I had sanded grout.
You can go get what you really want, a 100 percent silicone in satin or sanded texture, from the folks at ColorRite in colors to match any brand of grout on the market.
Unread 01-15-2020, 09:39 PM   #153
Lucy_Dawg
thanks CX, that is exactly what I will do. I want the sanded look, and I want to be 100 Silicone, and good mold/mildew resistance.
Paul
Unread 01-16-2020, 08:33 AM   #154
Yup.
In a complete boneheaded move I made that exact mistake; used a non sanded color matched silicone for the wet areas, and a sanded color matched acrylic in the non wet areas, both were the same color.
The difference is striking, and not in a positive way.
Unread 01-20-2020, 08:40 PM   #155
Lucy_Dawg
So I ordered the color-sil 100% sanded grout, and then cut out the existing with a razor blade. Question is, exactly how clean should I remove the old stuff? Is there a trick? I have it pretty clean, but every now and then you can see a small spot like a slither inside the cracks.
Paul
Unread 01-20-2020, 09:47 PM   #156
I can't see what you have from over here, Paul, even when I squint real hard. 'Specially when you don't have a geographic location in your User Profile and I don't even know which direction to look, eh?
All I can tell you is your new silly-cone will not stick to your old silly-cone, so you'd like your old silicone to be all gone. Up to you how gone that is.
The purpose of the silicone is to allow for movement accommodation while providing a more aesthetically pleasing joint. The joint you have with nothing at all in it is quite effective, just not too pleasing to the eye, eh? Whatever you do will likely be an improvement, but the cleaner the joint you start with the longer lasting will likely be your re-grouting endeavor.
Unread 01-23-2020, 10:59 PM   #157
Lucy_Dawg
So Colorite messed up my order, and sent me some high gloss/sanded mixture. The color was good. I thought that this caulk looked greasy, but that wasnt grease, it was gloss. Unfortunately, I am now going to have to cut this crap out again, for 2nd time. I will be reinstalling the original, 100% silicone caulk in color match from Custom Building Products. 1/2 the costs, color matches better, and applies easier, and has less sheen that the Color-Sil.
Paul
Tile an old concrete foundation?? heyjude Tile Forum/Advice Board 4 03-08-2016 02:00 PM
Marble thickness-is a 5\16" thick 2" Carrara Hex over concrete subfloor thick enough? Babydoll66 Tile Forum/Advice Board 18 08-13-2015 04:43 PM
Tiling over concrete foundation stardog7 Tile Forum/Advice Board 5 11-13-2013 05:13 PM
How thick on that first slope? Fiddle1 Tile Forum/Advice Board 10 01-10-2008 09:15 AM
concrete foundation hef Tile Forum/Advice Board 9 03-24-2004 12:14 PM
