Unread 09-08-2019, 03:46 PM   #181
SpaceCadet
Tub surround is complete. We tried it out and nothing has burst into flames yet but I do see a non-critical problem. The enameled metal (Americast) tub is a bit warped so the front part adjacent to the pipe wall slopes toward the floor and I end up with a small puddle in that wall/tub/floor corner below. That corner is waterproofed but I'd rather not have water sitting there. I could run a bead of white silicone to keep that water off the floor but that probably wouldn't look great. Anything I could do that would work and not look like crap?
Paul
SpaceCadet is offline   Reply With Quote
Unread 09-16-2019, 04:02 PM   #182
SpaceCadet
Here's a light one. Installed toilet bowl and caulked around the base. Left a gap in the back. Used plain white silicone reasoning it would match the toilet. And it does but the bowl needed shimming and there's a pretty noticeable groove around the base now.
Wife doesn't see anything wrong with it but I'm not crazy about the way it looks. Is this at least normal looking or does it stand out as irregular?
My other choices are use white silicone but tool it vertically with a square piece of plastic instead of grooved, use clear silicone, or use the silicone color/texture-matched to the floor grout. Vertical tooling would be a pain to clean up, wife isn't keen on the clear, and I didn't choose the color-match in the first place because it's technically a "wall" joint. Opinions?
Paul
Unread 09-16-2019, 04:37 PM   #183
If it needs shimming, install the shim and mark it where it goes under the toilet. Remove the shim and cut it at the mark, then reinstall the shim so it's not visible, at least not from standing height.
Then a caulk bead would hide it.
Or, option 2:
Use more caulk.
Unread 09-16-2019, 04:49 PM   #184
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I've found translucent silicone to be a lifesaver in cases like this. Because it's translucent it "takes on" surrounding color, but not clear and not stark like white.
Maybe too late now...
I thank my countertop fabricator for clueing me in to it. I've used both of these.
https://www.amazon.com/CRL-Transluce...gateway&sr=8-3
or
https://www.amazon.com/Dow-Corning-7...gateway&sr=8-4
Peter
Unread 09-17-2019, 06:03 AM   #185
SpaceCadet
Thanks for the tips.
Kevin: That's pretty much exactly what I did. I mean the shimming, not the bird's nest of caulk in option 2.
Peter: It's not too late. I might cut out the white silicone and redo it. That translucent silicone is probably what I should have used.
Paul
Jason's Small Shower Rebuild wkumtrider Tile Forum/Advice Board 132 05-09-2017 01:50 PM
starting bathroom rebuild efjellanger Tile Forum/Advice Board 37 12-16-2013 10:42 PM
Bathroom Gut & Full Rebuild. GreatWhiteNowhere Tile Forum/Advice Board 2 04-30-2012 09:26 AM
Bathroom rebuild - gonna have some questions sdl Tile Forum/Advice Board 5 11-25-2011 01:11 PM
Help!...Demolish/Rebuild Small 35-yr-old Bathroom sinkholed Tile Forum/Advice Board 54 08-04-2007 09:14 AM
