Unread 02-02-2013, 04:36 AM   #1
Florida Beach House
How to install ceramic tile to metal fireplace
Hi Everyone,
I just installed a wood-burning metal fireplace and I'd like to tile the surround so that the metal does not show, even at the edges. I've read all the posts I can find on the forum on this subject, but most of them are several years old and I wondered if methods and materials might have changed.
Some posters advocated attaching lathe to the metal with self-tapping screws, but I'd rather not penetrate the enclosure.
Others recommended using Latacrete 310 directly on the metal, but the manufacturer's website rates it only to 95 degrees, which the fireplace must exceed.
Loctite makes a high temp red rtv silicone for installing ceramic tile in coal fired power plants (rated to 600 degrees), but not sure this would work in residential application.
The stove manufacturer is no help on this, unfortunately. If it makes any difference the metal enclosure is not painted black but is stainless metal.
Any help would be appreciated.
Neil
Florida Beach House is offline   Reply With Quote
Unread 02-02-2013, 11:35 AM   #2
You may want to wait until Monday when Danielle, our resident laticrete rep is back or their tech support is open. I am of the belief that 310 is the preferred adhesive for thisapplication.
Sent from my new crappy phone
Unread 02-02-2013, 01:12 PM   #3
Welcome, Neil.
Think you'll find that temperature limit you reference is for the application of the product rather than an in-service limit. The range of 90 to 95 degrees Fahrenheit wouldn't even qualify either the Latipoxy 300 or 310 for exterior applications if that were the service limitation and both are rated for exterior use, I believe.
I would contact Laticrete to see what the upper temperature limits might be, but the 310 is, as Paul pointed out, recommended for your application in general.
Unread 02-02-2013, 02:07 PM   #4
CX is right, black granite applied to a building exterior in any southern climate would easily reach temps over 95ยบ in mid February.
Unread 02-02-2013, 04:35 PM   #5
yeah I would pass on trying to make that happen.
some things are just not meant to be and if you can conjure up some
fancy way, more and likely it wont last too long in the sun & rain down here.
Unread 02-03-2013, 02:31 PM   #6
Florida Beach House
Thank you everyone for the replies. It is an interior job and it makes sense that the temp rating for during application. I did wonder. I'll wait until tomorrow to get some solid feedback from Laticrete.
Neil
Unread 02-05-2013, 01:32 PM   #7
Danielle@LATICRETE
Social Media Specialist at LATICRETE
Danielle@LATICRETE's Avatar
Hi Neil,
As pointed out by CX the 95 degree temperature you had referred to is the maximum temp during installation.
Once installed and cured, LATAPOXY 310 can withstand a constant temperature of 140 degrees.
Best Regards,
Danielle
Danielle Shpunt
dcshpunt@laticrete.com
Office: (203) 393-0010 x343
http://www.laticrete.com
Danielle@LATICRETE is offline   Reply With Quote
Unread 02-05-2013, 01:59 PM   #8
cwilde72
cwilde72's Avatar
Neil, I've done exactly what you are trying to accomplish. I used a refractory cement that I'd purchased from an online chimney supply store. Forget the name but you should be able to find one easy enough. This refractory cement had very similar properties to mastic but only comes in grey color. It is specifically designed to adhere stone to metal surfaces in high-temp installations. Did this job two years ago and it's still holding strong. I see the customer 2-3 times a week and he'd definitely let me know if there was a problem. FWIW the tile was a glass/natural stone (light stone) mosaic.
Chad Wilde
Precision Tile
Huron, SD
cwilde72 is offline   Reply With Quote
Unread 01-13-2020, 06:24 PM   #9
j123jam
Red face
Neil, I would love to hear what you ended up with and how it went! I'm installing tile (2" hexagon) around a Napoleon direct-vent fireplace with zero-clearance. The tile will mostly be on backer board, except for the edges where it's the metal of the fireplace. Right now it's looking like my best bet is a high heat silicone like Rutland RTV, but really eager to hear if you went with the Laticrete 310, refractory cement, or silicone.
Thank you!
Josh
j123jam is offline   Reply With Quote
Installing Ceramic Tile over black metal Fireplace surround jjcv Tile Forum/Advice Board 17 03-16-2018 03:15 AM
Tile on metal of fireplace - how to? vsheetz Tile Forum/Advice Board 3 03-08-2009 10:29 AM
How to attach tile to metal fireplace wmcknig Tile Forum/Advice Board 1 03-04-2009 08:00 PM
Tile On Metal Fireplace Help Higgy Tile Forum/Advice Board 40 12-07-2006 03:35 PM
How To Install Metal Lath With Scratch Coat /ready For Ceramic Tile Installation robzr1 Tile Forum/Advice Board 10 02-18-2006 08:41 AM
