Unread 04-30-2019, 04:05 PM   #46
Willy
I'm back to blow the dust off this remodel project. Life gets in the way and projects get put on hold.
Anyway, I have a question.
I am using a schluter kerdi-line drain. The area where the drain will be is 38" without any tile. I am trying to decide which length of drain to go with.
The KL1V60E90 which has an opening of 35 7/16" or
The KL1V60E80 which has an opening of 31 1/2"
The wall tile I will be using will be 7/16" thick. Will the larger of the two drains fit and look right when completed?
Scott
Willy is offline   Reply With Quote
Unread 05-02-2019, 07:58 AM   #47
Willy
Any opinions on my question above?
Scott
Unread 05-02-2019, 08:18 AM   #48
Don't know what you're measuring, Scott, but your numbers don't appear to quite fit any of the dimensions listed on the Schluter website.
Unread 05-03-2019, 04:18 AM   #49
Willy
CX, I got my numbers from this page.
Schluter Drains
I was looking at the actually drain size not the grate.
Scott
Unread 05-03-2019, 07:25 AM   #50
Don't know what the discrepancy might be, Scott. Maybe best you call the Mother Ship (800-472-4588) and ask them your question. I don't see your "Model KL1V60E90" listed at all and I don't know what difference the 1 in there might mean.
I've never installed one of their line drains other than at Schluter training workshops and we paid no attention to how they might actually fit in any particular shower layout.
Unread 05-03-2019, 09:20 AM   #51
Willy
Thank CX I will phone the mothership. I believe the “1” is the new packaging. Comes with a valve seal, pipe seal, and some corners
Scott
Unread 05-12-2019, 08:25 AM   #52
Willy
The 36" line drain fits!!!
I'll be doing the mud bed soon, can I use plastic under the lathe instead of roofing felt?
Scott
Unread 05-12-2019, 08:28 AM   #53
Yes, you can, Scott. Minimum 4mil polyethylene sheeting. Or any reasonable facsimile thereof, truth be known.
Unread 06-01-2019, 05:36 PM   #54
Willy
Got this done today. How long do I let it cure under the plastic?
Scott
Unread 06-01-2019, 07:44 PM   #55
How long you got?
If you're going over this with Kerdi, I'd let it set up at least overnight, but preferably until Monday. The longer you wait, the better.
Unread 06-01-2019, 07:52 PM   #56
Willy
Originally Posted by Kman View Post
How long you got?
I was going to give it several days. Yes I’m going over it with kerdi
Thanks for the reply!
Scott
Unread 06-15-2019, 01:33 PM   #57
Willy
Some more updates. The drain was set about 4-5 days after I put in the mud floor. I just Kerdi’d the floor last night. I have 1 more piece of ditra and a few pieces of kerdi band left to install.
I have a question? I will be using 12 x 24 porcelain tiles with some glass tile accent. I was planning on getting the T3 razor blade. Will that blade be good for both my porcelain and my glass tile? Somebody on another thread recommended a glass tile blade but it was $300, I’m not sure I want to spend that kind of money for just a few cuts.
Scott
Unread 06-15-2019, 01:42 PM   #58
Willy
Links to the tile I will be using
https://www.flooranddecor.com/porcel...2+x+24&start=7
https://tilebar.com/loft-royal-blue-...ass-tiles.html
Scott
Unread 06-17-2019, 11:51 AM   #59
The T3 is great for the porcelain. No way of knowing how it will work with the glass until you cut one.
The best way to cut glass tiles
Watch this ancient video
Montolit CPV is the way to go and less than $300
Unread 06-17-2019, 05:24 PM   #60
Willy
Thanks for the reply Paul. That is the blade that was recommended to me by another member. All the prices I’m seeing for the 10” version are close to $300
Scott
Scott's Master Bath Remodel strichzwei Tile Forum/Advice Board 176 03-06-2015 11:02 AM
Scott's master bath remodel Sbgamecock Tile Forum/Advice Board 11 09-28-2014 07:19 PM
Scott P's master bath remodel spearce72 Tile Forum/Advice Board 2 01-12-2012 04:08 PM
Scott's Master Bath- Help! zooluk Tile Forum/Advice Board 58 03-01-2010 03:50 PM
Scott's Master Bath/(project 1) Scott_Francis Tile Forum/Advice Board 14 05-23-2007 08:08 PM
