Unread 04-23-2022, 04:32 AM   #1
nbohm
Remove shiny thinset or grout residue on latex paint!
For the 1st time I had someone else install tile for me (I typically do my own). While they generally did a great job, I find in the 3 inches adjacent to the tile (on the latex painted wall) a shiny residue on the paint that won't clean off with water.
I assume it's either (Mapei) thinset or grout residue left after incomplete cleaning during installation.
I haven't yet gotten more aggressive with cleaning.
Any thoughts of how to remove the residue without removing the paint?
Cleaning, if possible, would be much preferred to repainting...
neil
nbohm is offline   Reply With Quote
Unread 04-23-2022, 06:40 AM   #2
PC7060
PC7060's Avatar
Hi Neil, I hate it when people don’t color inside the lines.
I’ve found white vinegar to be very effective for thinset. Hit or miss for grout depending on type. Cheap and easy to apply with spray bottle.
Unread 04-23-2022, 10:10 AM   #3
Welcome to the forum, Neal!
Are both suspected materials cement-based? Specifically, which thin set and which grout was used?
Unread 04-24-2022, 05:52 AM   #4
nbohm
It was Mapei Keraflex thinset and a pre-mixed Mapei grout (not sure the name). I have now tried straight vinegar and Windex to clean with absolutely no change. I have not 'soaked' it with anything.
The strange thing is you can see it as a shiny area on the paint with defined borders like something was wiped on/off. You can't feel anything at all, like a raised surface.
Maybe it's not ON the surface, maybe it somehow ate into the paint and I have to repaint?
neil
Unread 04-24-2022, 12:50 PM   #5
PC7060
PC7060's Avatar
Entirely possible. Personally I’ve learned those transition zones will require repainting or at least some touch up.
Unread 04-24-2022, 04:23 PM   #6
It’s probably very helpful to research the name of the grout used because we need to know what we are dealing with. The fact that it’s shiny points to the grout. If this is leftover polymers, a high alkaline cleaner may be your answer. But, again, knowing which grout was used will keep us from taking pot-shots in the dark.
Unread 04-24-2022, 08:49 PM   #7
smifwal
Sounds like flex color cq, unless mapei is making another*ready to use grout* the shiny might be the resin
Unread 04-25-2022, 05:30 AM   #8
nbohm
Thanks for your thoughts.
I just bit the bullet and repainted. Fortunately my custom mix paint matched so I didn't have to do the whole wall!
neil
Latex Paint Basement over old Paint before tile mitrellim Tile Forum/Advice Board 5 08-10-2013 09:18 AM
Latex Paint on Unsealed grout tfeeney29 Tile Forum/Advice Board 2 08-11-2010 08:45 PM
shiny residue after spectralock Hox Tile Forum/Advice Board 2 05-13-2008 04:35 PM
Latex paint for grout color??? san0696 Tile Forum/Advice Board 4 03-29-2007 07:10 PM
Vinegar & Water to remove thinset residue?? PharmD Tile Forum/Advice Board 2 01-11-2005 01:17 PM
