Unread 04-22-2007, 05:48 PM   #1
RollTideFan
Help, What kind of thinset for granite tile?
Hey Guys,
Can someone tell me what kind of thinset to use for laying granite tile as a counter top? It will be backed by 3/4 plywood and 1/4 hardibacker.
Also, what kind of thinset do I use to lay a 6" ceramic tile backsplash directly to sheetrock?
Thanks for the advice you guys are great,
TideFan
RollTideFan is offline   Reply With Quote
Unread 04-22-2007, 05:57 PM   #2
Hi Tide fan, welcome. I like using a medium bed thinset for stone, it allows you to butter up if you need to without the stone sinking from it's own weight. Customs makes Marble and granite thinset that I use alot.
On the splash, you have several options here. You can use the same Marble and granite thinset or go to a little cheaper modified thinset like Versabond. Mastic can also be used.
Unread 04-22-2007, 06:04 PM   #3
RollTideFan
What about a brand or name. Duraflex??? Something I can get at HomeDepot or Lowes??? Thanks
Unread 04-22-2007, 06:06 PM   #4
ddmoit
ddmoit's Avatar
Here's the Marble & Granite that Davy mentioned. It should be readily available at Home Depot.
http://www.custombuildingproducts.co...er=diy&lang=en
Dan - a DIYer in SE Tennessee
