Unread 11-13-2013, 01:09 AM   #1
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Kiln Release Marks on Porcelain
Ever seen this before? Noticed after setting of course. At first it looks like just dust that would wipe off.
But the glaze is actually damaged. You can only see it when you look at it from an angle into the light. I'm assuming the manufacturer stacked the tiles before the glaze cured. The pattern in the glaze is the same as the back of the tile.
On a 1000 sqft job we found about 20 tiles. 10 off them are already set before we realized we had problem.
I've set some tile made in China that is of decent quality. This is not one of them.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 11-13-2013, 01:12 AM   #2
That's a bummer. Sorry.
Unread 11-13-2013, 02:05 AM   #3
PetrH
on the plus side, they look to be quite even in size. I've seen some chinese tile that was "rectified" to +/- 1/8"
Petr
PetrH is offline   Reply With Quote
Unread 11-13-2013, 04:12 AM   #4
TonE
Quality control in china. it's only 2 percent.
Consider yourself lucky.
Tyler
TonE is offline   Reply With Quote
Unread 11-13-2013, 08:34 AM   #5
Floorit
Tile, Stone and Hardwood
Floorit's Avatar
Isaac,
I had that same problem back in February. Also Chinese made, private labelled for a large tile co. The tile also had a shading issue on some that appeared to give them a striped appearance if you saw them in the right light reflection. Could not see either problem until after the tile was down and grouted. Not fun at all.
Ray
Germantown Tennessee Tile Stone Hardwood Installation
NWFA Member
Tennessee Installer of Schluter Kerdi Waterproof Showers
Tennessee Installer of Laticrete Hydroban Waterproof Showers
"Life is pretty simple:you do some stuff. Most fails. Some works. You do more of what works. If it works big, others quickly copy it. Then you do something else. The trick is the doing something else." Leonardo Da Vinci
Floorit is offline   Reply With Quote
Unread 11-13-2013, 09:08 AM   #6
Isaac, have you tried some sulfamic acid to get the kiln slip off ?
Unread 11-14-2013, 02:14 AM   #7
The store I bought it from called the tile manufacturer rep and he recommended this acid cleaner-
Dupont Restore-
http://www2.dupont.com/Stone_Tech_Pr...c_cleaner.html
I don't have any yet, but tried Brian's suggestion with the Sulfamic Acid. It didn't seem to make a difference. May need to let it dwell longer. I mixed it pretty strong.
Also tried Aqua Mix Nano Scrub.- After scrubbing really hard it seemed to get better but not completely gone. May have to pull out the floor machine.
Isaac
Maui, Hawaii
Unread 11-14-2013, 08:36 AM   #8
Floorit
Floorit's Avatar
Isaac & Brian,
On my issue, I used sulfamic acid, nano-scrub, blaze, vinegar, and glass cleaner, at various times, left them set anywhere from about a minute to an hour, used white scrub pads, clean cloths, sponges, etc. to no avail. I spent a ridiculous amount of time trying to resolve the issue. It's in the tile and it ain't coming out. It all had to be replaced.
Ray
NWFA Member
Unread 11-14-2013, 10:22 AM   #9
Arizona Floors
ReTile
Arizona Floors's Avatar
I'm with Brian, it's kiln release (kiln slip- I haven't heard that term) that was transferred from the tile backs to the tile fronts during shipping and or storage.
The good, it can be removed without too much trouble.
The bad, I only know a restoration guy who can do it here. The most info he would give me was he used a combination of 3 things, whatever that meant. He makes a killing cleaning the tiles, the only other option is remove and replace.
Almost a year ago our local Emser Tile had a run of about 150,000 ft that was installed with that exact problem. Emser hired that restoration guy to clean the tiles.
Sorry, I know it's not helpful. But the manufacture should step up on this one especially if it comes down to replacement.
Arizona Floors is offline   Reply With Quote
Unread 11-14-2013, 01:48 PM   #10
ClaimsGuy
Chances are strong that its kiln release.
If so, the tiles can be cleaned using a variety of solvents - I've seen some get cleaned with water, and others that require very strong acids. Common sense suggests that you start with the weakest stuff first.
The best method I've found so far uses a floor machine and a mild tile cleaner. If you don't have that machine available you can use acid or scrub it off with a nylon brush.
And yeah, we had to deal with a lot of this problem fairly recently, but found a permanent fix. Just put a sheet of paper between the tiles - its as simple as that.
Any other manufacturers reading this, take note!
Sales Support at Emser Tile & Natural Stone
www.emser.com
ClaimsGuy is offline   Reply With Quote
Unread 11-14-2013, 02:53 PM   #11
Arizona Floors
ReTile
Jeff, I wasn't throwing Emser under the buss, I didn't think about that when I posted.
It should be added, as far as I know, every job that had the kiln release issue was remedied by Emser immediately. And it's great that there are preventative measures now in place.
Unread 11-14-2013, 08:01 PM   #12
if the sulfamic didn't work I can say the Restore wont do a thing. its not as strong.
calcined alumina-silicate engobe = clay slip, kiln slip, kiln release,
the ceramic rollers are sprayed with it to help the freshly fired tile "slip"
off them while they are still hot. that an the pattern on the bottom of the
tile that reduced the surface area that contacts the rollers.
Unread 11-14-2013, 08:11 PM   #13
Isaac,
I found this article that might help.
removing-kiln-release-marks-on-porcelain
Unread 11-14-2013, 08:44 PM   #14
Brian, I know you don't need any additional compliments but your web skills are pretty impressive, almost as good as your plank tile skills.
Thanks for tracking down that article. That is exactly the problem.
Interesting that I noticed the boxes did appear to have gotten wet at some point and the pallet was shrink wrapped holding in the moisture.
(When they added the thinset on the added extra shrink-wrap on top of the original.)
And if you look closely in the second picture you can see the roller marks.
I think this thread should be renamed- "Kiln Release Marks on Porcelain"
Isaac
Maui, Hawaii
Unread 11-14-2013, 09:56 PM   #15
Peerless Tile
Tile Contractor
I know much wiser people than I have responded...but have you tried barkeepers friend....a bit abrasive and a bit acidic as well....a cheap try at it...
SC Greg
Peerless Tile is offline   Reply With Quote
Kiln release Grovertile Professionals' Hangout 53 04-24-2017 06:41 PM
Spectralock On Textured Porcelain - Do I Need A Grout Release? JC-TX Tile Forum/Advice Board 6 10-22-2013 11:03 PM
Furniture marks on porcelain tile RBard48 Cleaning, Restoration and Sealing 2 03-13-2013 01:20 PM
porcelain tiles with drywall mud marks Theresa Cleaning, Restoration and Sealing 2 08-19-2006 10:01 AM
Pencil marks on porcelain tile jeffdeline Tile Forum/Advice Board 2 06-30-2004 07:16 AM
