Originally Posted by sugaree53
The sub-floor is oak hardwood and in good shape. Do I need plywood over it before I put the hardi board?
Yes. Absolutely...solid dimensional wood expands and contracts too much and you need plywood to insulate the stiff tile from this movement. I'd recommend removing that oak finished floor so you don't gain so much thickness when you add the ply.
Do I absolutely need to add a moisture membrane like those kerdi sheets?
If you're using Kerdi to waterproof the walls, then you don't need a moisture barrier behind the substrate you're applying Kerdi to.
..... Now on the walls there are remains of an old tile installation that was removed. I can see some old mastic. Can I leave the existing drywall up which has been covered with joint compound in most places and then cover it with the hardi board then tile over that or just tile directly onto the drywall with just some sanding to get it smooth?
Oh...geez...that's, well.....
Let's ask more questions to get a better idea of what's going on here and what you're trying to accomplish. Is this for the area inside or outside the tub....or both? Is the tile going up to the ceiling? Adding to the walls will thicken it up and this can cause a problem on the tub where the back "shoulder" of the tub is comparably thin....and this extra thickness typically means you need to address the edge of the tile so you don't see the Hardibacker? Is this a lath and plaster wall that you're trying to avoid removing? What do you see as the reason not to simply remove the walls and replace them with drywall?
