Unread 01-11-2021, 04:46 PM   #1
Shanti
Mortar over painted tile fireplace - advice please
HI -
We have a brick fireplace that was covered with granite tile, that tile was later painted. We want to create a concrete style fireplace and will be using a clay paint that looks like concrete. We are unsure how to proceed with the tile. It is impossible to remove the tile w/o ruining the brick underneath. We would like to mortar over the painted tile to smooth out the grout lines and then apply the call paint to get a smooth concrete finish. My question: can we mortar right over the painted tile? Do I need to strip the paint? Do we need to first put up a metal lathe? Do we need to just put cement board over the whole thing? TIA for your help!
Shanti
Shanti is offline   Reply With Quote
Unread 01-11-2021, 04:55 PM   #2
If it simply can't be removed, at the minimum, I would use a cup grinder or perhaps a sander with some aggressive grit paper to rough up/remove as much of the paint as possible. If most of it comes off...go for it. If not, paint on some Mapai "Prime Eco Grip" as a base to tile on......
Unread 01-12-2021, 10:46 AM   #3
diddly
fireplace
Eco prim is a great product but Not having data sheet I dont know if it can be used over painted surface.
Bookie
Bookie
diddly is offline   Reply With Quote
Unread 01-12-2021, 12:32 PM   #4
Joetile123
Eco Prim Grip.
SURFACE PREPARATION
• All substrates must be structurally sound, stable, dry,
clean, and free of any substance or condition that may
reduce or prevent proper adhesion.
• Thoroughly clean all surfaces of any substance
that could interfere with the bond of the installation
material, including paint, asphalt, wax, oil, sealers,
curing compounds, and poorly bonded or incompatible
adhesive.
• Repair cracks in the substrate before proceeding.
• Expansion and movement joints must be honored
though the finished flooring system.
• Do not acid-etch surfaces before applying ECO Prim Grip.
Joe
Joetile123 is offline   Reply With Quote
Unread 01-12-2021, 01:13 PM   #5
Hi Shanti,
It's for sure you're going to ruin the granite tile, why not just remove it and then mortar (float mud) over the bricks? The bricks will be rough enough to grip the mortar.
advice on tiling fireplace area over painted drywall (pics included) tileam2000 Tile Forum/Advice Board 4 08-20-2019 09:11 AM
tiling over painted tile on fireplace Fern4 Tile Forum/Advice Board 4 11-11-2016 11:22 AM
Tile over textured/painted Durock on Fireplace blackwood99 Tile Forum/Advice Board 4 02-01-2012 08:55 AM
Slate Tile Over A Painted Brick Fireplace Stevotx Tile Forum/Advice Board 7 01-24-2009 10:38 PM
Painted tile advice staceyrussell Tile Forum/Advice Board 5 04-27-2005 07:15 PM
