Unread 03-05-2021, 09:37 AM   #4801
smifwal
Not the worst, bit I don understand it.why not put the cut tile in the shitter
Unread 04-05-2021, 12:31 AM   #4802
RightUp Sam
Becoming a Rakyat Warrior
So I'm not sure I'm doing this right (should I download and save the photos, and post them here directly?), but I stumbled across this on Facebook this evening and thought you guys should see it.
https://www.facebook.com/Firsthandco...0778905036505/
I'm not wrong in thinking that shower is going to leak like a WAG's diaphragm, am I? I don't see any waterproofing at all, and they've got screws all through--well, all of it. And that in a year or two they'll be able to harvest mushrooms off the wood used for that bench (once they drain all the rancid water away)? I could do a better job than that, and I'm not a professional advertising this as good work on Facebook.
Stacey
RightUp Sam is offline   Reply With Quote
Unread 04-05-2021, 08:51 AM   #4803
Yes, you should.
No way to know anything at all about that photo at that stage of construction, Stacey. There may be a plan.
Unread 04-05-2021, 09:54 AM   #4804
RightUp Sam
It's a slideshow, Cx--you have to click the little right-hand arrow.
I could be wrong and it's something like DensShield on the walls--I'm not familiar enough with all the various backers to know if it's a gray one or regular drywall or cement board--but it still looks like it wasn't screwed in/sealed properly to me.
Stacey
Unread 04-05-2021, 10:07 AM   #4805
Well, they waterproofed part of the bench, sorta, and it's got a nice door. What's not to love?
Unread 04-13-2021, 09:28 PM   #4806
Jim Farrell Tiler
Jim Farrell Tiler's Avatar
this one is pretty bad, i only got involved after the builder stripped it, it was a existing tile shower that the owners wanted to retile so the plan was to remove wall linings, take up floor tiles, re waterproof etc retile, turns out the walls had been leaking for years, there were 2 layers of tiles on the floor, (black tiles and under them white tiles) no indication it was leaking, luckily its on a slab or the floor would be gone as well ...now its a rebuild
Jim
Jim Farrell Tiler is offline   Reply With Quote
Unread 06-03-2021, 09:52 PM   #4807
RightUp Sam
Thought you might enjoy this. This (photo 1) is the result of a "professional setter," a subcontractor, it seems, who (if I'm understanding the HO's post correctly) blamed the store where the HO bought the tile and the HO herself, for not getting a "jigsaw" tile.
The tile store, when called, managed to make it worse by asking to be allowed to send someone out to grout it to see if that would "fix" it (photo 2).
And I *know* I'm not wrong about the lack of waterproofing here; I honestly cannot see how they plan to correctly waterproof the big gaps around the edges.
The discussion is here, if anyone is interested:
https://www.houzz.com/discussions/61...tile-in-shower
Stacey
Unread 06-03-2021, 11:13 PM   #4808
CaliGrown
CaliGrown's Avatar
Shody stuff, looks like a kerdi and topical hybrid/combo. Doubt the flood test was done...
“ Most times ya set tile, other times tile sets you!”
Christopher Machado
https://www.machadotileco.com/
Unread 06-04-2021, 08:15 AM   #4809
smifwal
Lots of things wrong in this house, tile set over plywood (he couldn't figure out why it was cracking and popping) sheetrock set with 4 corners touching, and about half the screws as needed, tile set over purple rock in the tub and the highest polished slippery tile on the floor outside of the tub. Guys is a master plumber by trade and very good at that but remodeling, not so much. He told me his life goal is to flip houses...
Unread 06-04-2021, 09:38 AM   #4810
jerrymlr1
WowShawn! That’s definitely a bona fide worst tile job. Are you gonna fix that mess?
Jerry
Unread 06-04-2021, 12:14 PM   #4811
smifwal
No sir hell I wasn't even over there to look at the tile, I went to look at the sheetrock cause he said he couldn't get anyone to finish hanging and then mud and tape it. And I seen why. I asked about the tile and he told me that the house had a terrible slope to it(3/4" in 2') but he didn't want to spend the money on self leveler, so he did a section with something similar to deck mud and then feathered it out and sIapped some tile down. He didn't think there was anything wrong with what he did. I mudded and tapped the master bedroom so he could paint and trim it out and move in, in exchange for him pulling a permit so I can replace the main water line in my new disaster house
Unread 08-21-2021, 06:53 PM   #4812
Installer's nightmare....
Unread 08-21-2021, 07:28 PM   #4813
jerrymlr1
LMAO! Unbelievable. Work looks good. The installer obviously is not afraid of a good challenge.
Jerry
Unread 08-21-2021, 08:23 PM   #4814
Well, it's all straight lines, so it should be doable.
Unread 10-02-2021, 11:45 PM   #4815
orangewood
Impressive...
if it's real, that is.
Casey
orangewood is offline   Reply With Quote
Absolute worst tile finishing job pitterpat Professionals' Hangout 17 04-02-2007 07:12 PM
worst of the worst... botched jobs Dan O'Connor Tile Forum/Advice Board 5 02-22-2007 03:21 PM
best and worst tile saw in $300-$500 range LinLee Tile Forum/Advice Board 9 01-30-2006 01:50 AM
best and worst tile saw in $300-$500 range johnnyaico Tile Forum/Advice Board 10 01-27-2006 03:05 PM
The worst job................ opiethetileman The Mud Box 6 10-08-2004 10:48 PM
