Unread 01-12-2007, 01:29 PM   #1
sohcrates
How to remove rubber gasket from pre-formed shower pan
Hi
I am removing an older pre-formed shower pan to replace it with a new swanstone pan and the drain is a pvc pipe with a pressure fit rubber gasket. that is all keeping it in place right.
Ive been digging at the rubber gasket for an hour but can only succeed in getting pieces of it off.
Any helpful hints? there must be an easier way to do this!
thanks
Alex
sohcrates is offline   Reply With Quote
Unread 01-12-2007, 05:09 PM   #2
sohcrates
update: i drilled about 20 concentric holes in the pan and was able to lift most of the pan out...but now i have a small circular piece of shower pan stuck to this darn pvc pipe with a rubber gasket holding it on. hmmm.....i'd prefer not to have to saw the pvc pipe off if i can help it....
Unread 01-12-2007, 05:15 PM   #3
ddmoit
ddmoit's Avatar
I would saw the pvc. It's easy enough to fix.
Dan - a DIYer in SE Tennessee
Unread 01-12-2007, 07:02 PM   #4
MudMaker
MudMaker's Avatar
Alex,
Ya just gotta keep on diggin... Sometimes a pair of needlenose pliers will do but most of the time ya just have to get in there and pry it out...
mm (aka "Paco")
