Unread 01-05-2010, 10:17 PM   #1
Steve C
Steve C's Avatar
Change of plane: grout or caulk?
I posted a question on my thread big bath build/remodel on the Tile Forum/Advice Board this a.m. and have yet to receive any replies, so here goes.
I'm building a 6' square Kerdi shower, and am installing tile now. In the Kerdi Shower book, John mentions using grout instead of caulk for changes of plane, although the conventional wisdom is to use silicone. Since the Kerdi is waterproofing everything any hairline cracks in the grout will be cosmetic.
I've explained this to the homeowner, as well as given him access to the shower book, and he would like to use grout (we already have Spectralock on hand). I'd like to use grout too, but would like to verify that we're doing the right thing.
Anyone here interested in giving me their opinion on this? Seems like everyone recommends the shower book, so just wondering if this bit of info is still valid.
Steve
Steve C is offline   Reply With Quote
Unread 01-05-2010, 10:24 PM   #2
Shawn Prentice
You need expansion joints at changes of planes because of the variations in expansion and contraction of the different planes. You also need them when dissimilar materials come together, i.e. fiberglass to tile, etc. Silicone is better than your latexes (sp?).
Use a neutral cure silicone for the best results. Laticrete, TEC both have them, or in a pinch, GE's silicone II is neutral cure.
Shawn Prentice is offline   Reply With Quote
Unread 01-05-2010, 10:25 PM   #3
MNTileGuy
Central Texas Tile Guy
Steve-
You'll get responses all over the board on this. In fact, I recall a pretty spirited thread we had going awhile back on this.
Personally, I use color matched caulk. But for every person like me, you'll get one that says grout...
Brad Bressler
Bressler Tile and Stone
www.bresslertile.com
Unread 01-05-2010, 10:27 PM   #4
The Kid
The Kid's Avatar
Neither, i use silicone. Latasil that is. Grout cracks, color match caulks are short lived, but silicone works great. its more expensive and its harder to apply but its good stuff.
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Unread 01-05-2010, 10:33 PM   #5
MNTileGuy
I agree that silicone is best, at least in showers if you can get it color matched.
In my area, you can't just buy it off the shelf. You have to order it in for big $$$.
You folks in the more evolved parts of the tile world don't have that problem I guess.
Brad Bressler
Unread 01-05-2010, 10:53 PM   #6
muskymike
muskymike's Avatar
I grout every corner. Using Kerdi you won't get cracks too often.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 01-05-2010, 10:53 PM   #7
LAtileman
Send a message via Yahoo to LAtileman
Caulk is good. I've heard that spectralock in corners can actually cause the tile to crack rite next to the joint, apparently the tensile strenght of spectralock is higher than the tile.
Moral of the story - keep epoxy out of the corners!
LAtileman is offline   Reply With Quote
Unread 01-05-2010, 11:45 PM   #8
Steve C
Steve C's Avatar
Thanks for all the quick replies. Tomorrow I'll see if my supplier (Prosouce) can get Latasil. Their website makes it look like I should be able to match the Spectralock.
Steve
color caulk to use, and caulk or grout first? muscat Tile Forum/Advice Board 6 06-29-2009 11:23 PM
Inside Corner Grout? Caulk vs Grout? Brion Tile Forum/Advice Board 11 08-25-2008 06:52 PM
how to grout using a caulk tube or grout bag? maneuen Tile Forum/Advice Board 3 01-02-2008 02:45 PM
Use only caulk or grout then caulk CalBear Tile Forum/Advice Board 17 07-04-2004 12:04 PM
