Industry standards call for 100% of the edges, and at least 90% coverage over the entire rest of the tile on a wet surface (like in a shower).
FIrst, you need to burn thinset onto the wall, then add more and notch it...then, burn a coat on the back of those larger format tile, then set the tile. On a larger tile like that, the only way you'll collapse the ridges of the notches is to move it back and forth across the notches. Those voids behind the tile can lead to moisture buildup, and the lack of full coverage will also make the bond MUCH weaker. While you might not notice on a porcelain tile, if it were say a natural stone or a glazed ceramic, those voids would likely end up making the tile show striping after awhile from the variations in moisture that got behind. Neither the tile nor the grout is waterproofing, and some moisture will get behind the tile in a well- used shower.
