Unread 04-29-2017, 08:25 PM   #1
Jeffksf
Change of plane grout/caulk question
I'm currently tiling my tub surround and it has a niche. My question is i know that changes in plane corners should be caulked instead of grouted, does that go for the niche as well? The niche is 42" tall between 2 existing wall studs. The niche is constructed using plywood, 2x4, hard I backer, and redgard waterproofed.
Sent from my SM-G920V using Tapatalk
Jeff
Jeffksf is offline   Reply With Quote
Unread 04-29-2017, 08:45 PM   #2
rmckee84
rmckee84's Avatar
Yes, 100% silicone for all changes of plane in the niche.
Ryan McKee
Unread 04-29-2017, 09:10 PM   #3
The alternative to caulk is an engineered joint. A bunch of companies make them to include Custom Building Products and Schluter (probably the oldest and largest supplier with the biggest variety). Those can either be mostly hidden, or a design statement depending on the type and color and material it is made of.
need help with: "baseboard" tiles (not cove)... caulk, grout, gaps, change of plane filamentary Tile Forum/Advice Board 24 11-16-2015 09:52 AM
Caulking a change of plane - always? M3 Pete Tile Forum/Advice Board 10 04-05-2012 01:16 PM
Change of plane: grout or caulk? Steve C Professionals' Hangout 7 01-05-2010 11:45 PM
Shower floor caulk on change of plane problems kcndc Tile Forum/Advice Board 5 02-24-2009 07:08 AM
Where to grout, where to caulk (plane changes) gof Tile Forum/Advice Board 16 09-22-2003 05:27 PM
