Unread 12-24-2022, 11:36 AM   #76
I've never used that mortar, Nelson. Did you check the bag for the manufacture date?
Unread 12-24-2022, 12:46 PM   #77
nelsonxn
Yes, the date code is: E12J2206
E = factory?
12 = date of the month
J = October
2 = 2022
So, if I'm correct it was manufactured Oct, 12, 2022 and i purchased it Dec, 20, 2022. So, it should be good.
Since i never pulled a tile at 12 hrs, I'm not sure what the mortar looks and feels like. I did pull another tile i cracked after a few days off the wall and the mortar was rock hard. I had to use a small air hammer to help pull it off the wall.
I've been reading that mortar is 60% cured after 24 hours and takes about 28 days to reach full strength. I'll speculate that it will be cured to about 30% after 12 hrs. But i'd still like to know what the consistency of the mortar is after 12 hrs.
I'm wondering if the problem is lack of humidity. Since we are in Dec and we don't have a humidifier, its possible that the mortar dried out too much before curing appropriately after 12 hrs.
I'm going to mix another batch of the same mortar on that tile with a water content on the higher side of the recommended 6.5 to 7.5 qts per 50 lb bag and also continue to moisten the wall and back of the tile, wait 24 hrs and see if i can pull it off the wall. If it comes off, then i think i have bad mortar.
Nelson
nelsonxn is offline   Reply With Quote
Unread 12-24-2022, 03:20 PM   #78
Originally Posted by Nelson, Post 75
The mortar was still damp - as expected, felt chalky, rubbed off easy, and pieces were somewhat crumbly.
Don't think it can be both.
Again, I've never used that mortar, and I don't know just what was involved with pulling your shim, and I think I don't even know what size tile we're talking about here, so I'm not sure whether you have a problem or not.
And I don't know how to read MAPEI's date code. I'll see if one of our MAPEI reps will verify that for us.
Unread 12-24-2022, 04:12 PM   #79
I find that I can pull shims out after 6-8 hours with no problem. On floors, I generally pull them out the next day and have never had the issues you have....
They didn't want it good, they wanted it Wednesday.
Unread 12-24-2022, 11:32 PM   #80
nelsonxn
well, i'm talking about a 14"x 5" rectangular piece, so not all that much surface area. Maybe i just pulled the shim a little too hard in the wrong direction.
I'll tile it again w/ mortar mixed w/ a little more water.
thanks,
Nelson
Unread 12-27-2022, 09:01 AM   #81
MAPEI - Technical Service
Company Representative
Sorry for being tardy to the party, those pesky holidays got in the way.
Below is an image to help decipher MAPEI batch codes.
I hope this helps!
Holden
http://www.mapei.com/US-EN/
Unread 12-27-2022, 09:05 AM   #82
Nelson, in regard to your concerns with the Ultraflex LFT not drying, this is a somewhat common occurrence around this time of the year.
I'm not sure what part of the country you are in, but colder temperatures cause mortars to cure and dry quite a bit slower. Chances are, if you had done this same exact thing in July, that tile would not have budged. Give the mortar it's full 24 hours before grouting or prying around it to remove spacers, excess mortar in the joints, and etc.
Please feel free to reach out if you need anything else!
Holden
Unread 12-27-2022, 01:58 PM   #83
Which is why, Nelson, we recommend all our visitors put a geographical location into their User Profiles. Helpful in answering all sorts of questions.
Unread 02-19-2023, 04:38 PM   #84
nelsonxn
Questions on silicon color and base molding
Well, I'm almost done with the master bath!
just a few questions...
  • I'm about to silicone the edge where the white jacuzzi touches the simulated grey marble tile shower wall. Is it normal or proper to use white silicone?
  • Does anyone have experience with using White PVC Base Moulding as apposed to primed pine?
thanks
Nelson
Unread 02-20-2023, 08:40 AM   #85
No experience with PVC base, Nelson, but have used PVC for crown molding in both of the showers I recent did. It's pretty easy to work with but don't know about its impact resistance in a baseboard application.
Unread 02-20-2023, 10:42 AM   #86
PC7060
PC7060's Avatar
Nelson, I’ve used the 3-1/4 PVC base on a couple projects. Bit bending so I recommend running a bead of adhesive (liquid nails) on tbe backside about 3/8 from top edge in addition to nailing. Power nailer makes job much simpler. I use a 18 gauge nailer for installing it to minimize the divot but any finish nail will work.
PC7060 is online now   Reply With Quote
Unread 02-20-2023, 03:49 PM   #87
nelsonxn
Ok, thanks.
I know this sounds like a stupid question... but...
What about the silicon? is it better to use white silicon on the edges of a white tub or jacuzzi no matter the color of the wall?
Nelson
Unread 02-21-2023, 07:36 AM   #88
PC7060
PC7060's Avatar
That’s your choice really. I tend to use a polyurethane sealant versus silicon. I find it hold up better and it’s paintable. I prefer Sikaflex All Purpose Sealant Polyurethane, typically available in grey or white at the big box stores. Takes a bit longer to set than silicon but doesn’t have a much schrinkage.
Bathroom renovation questions epagneul Tile Forum/Advice Board 2 11-28-2015 02:09 PM
Bathroom Renovation Questions Ross_in_AR Tile Forum/Advice Board 2 03-27-2013 10:03 AM
First bathroom renovation questions dataslayer Tile Forum/Advice Board 11 07-24-2011 05:46 AM
Bathroom renovation questions muskymike3 Tile Forum/Advice Board 2 11-30-2006 08:37 PM
shower renovation/drain questions dangerranger Tile Forum/Advice Board 12 05-12-2005 04:41 PM
