Unread 12-15-2010, 10:07 AM   #1
kholm
Mesh used to hold tiles together
Hi
My name is Kevin.
I'm needing some information. I'm trying to create a mosaic design with tile and was wondering if anyone has a link to someone or somewhere that I can buy the mesh used to hold the tiles together.
Thank you.
kholm is offline   Reply With Quote
Unread 12-15-2010, 10:23 AM   #2
I don't have a link to the mesh you need (probably can use the reinforcing mesh sold with waterproofing liquids), but you can use Kerdi-mat or Kerdi-band. Stretch the Kerdi onto a piece of plywood, then thinset the mosaic to the mat using thinset. When it cures, cut the Kerdi from the plywood and apply it to the wall. This works best in small sections, say 6 x 12 or so inches.
Unread 12-15-2010, 10:32 AM   #3
Muddman
Muddman's Avatar
It is a fiberglass sheet that is used most of the time. I use something similar in concrete countertop fabrication, we call it "fiberglass scrim". Here is a link to some you can order by the square ft. It is a little heavier than what you normally find with tile, but will still work. If you search around you may be able to find some with a tighter weave if need be.
http://www.concretecountertopsupply....NetByFoot.html
Gregg
www.muddmandesign.com
Muddman is offline   Reply With Quote
Unread 12-15-2010, 06:00 PM   #4
Honeydo
not sure how much you need, but here's a couple options
http://meshmountpaper.com/?gclid=CMr...Fcnc4AodpA23nA
http://www.mosaicartsupply.com/suppliesmosaictile.htm
Ed
Honeydo is offline   Reply With Quote
Unread 12-15-2010, 07:27 PM   #5
Muddman
Muddman's Avatar
Ed, cool, didn't know they sold things like that.
Gregg
Unread 12-15-2010, 08:09 PM   #6
WendyHMN
Amateur Jack of All Trades
WendyHMN's Avatar
Where do you live? Many major cities have mosaic supply stores that could really use your business. I did get my unglazed porcelain on closeout online, but all my supplies and tools came from the local place. So what kind of mosaic are you doing? Mine is a Roman theme.
Wendy
Unread 12-16-2010, 08:43 AM   #7
kholm
Mesh
Thanks everyone.
I live in Kansas City.
will tiles hold on the wall? scottg Tile Forum/Advice Board 4 07-04-2008 07:18 PM
mesh backing on mosaic tiles Kurt Shaw Tile Forum/Advice Board 3 05-13-2008 04:47 AM
crooked glass tiles on mesh teaforthetileman Tile Forum/Advice Board 2 10-23-2007 07:51 PM
3x3 tiles on mesh backer Richard S Tile Forum/Advice Board 4 11-07-2005 10:13 AM
cutting 2 x 2 tiles on 12 x 12 mesh maddiep Tile Forum/Advice Board 1 09-06-2005 04:54 PM
