Old 12-27-2012, 08:38 PM   #1
lrngasigo
Noisy plumbing behind tile
I recently had my remodeled - prior to the remodel it was tiled above, with a tub below. We pulled the tub and a mud pan was set, tiled a shower with shampoo niche. There is a bathroom/toilet on the other side of the shower in the adjacent bathroom. It has always been there, but now, when it flushes, a HUGE WOOSH is audible through the (master) bathroom...in our bedroom. This was barely noticeable before, but, LOUD now.
Why? All I can figure is it is because of the recessed shampoo niche...too little space? There was tile before...and tile now. No niche before. The type of backer board?
Could this have been forseen/prevented?
What can I do now? The bathroom on the other side is primed but not painted. It would not be totally out of the question to add some soundproofing around the toilet pipe...if it would help...by removing drywall and patching back up. But the toilet pipe makes a ninety, and, runs behind on the fixture end of the shower...and that would be trickier to access/fix. Maybe I'll get used to it, but, with a full house of kids, I can't imagine spending the next 18 years waking up in the middle of the night because someone had to go!
Nicole
lrngasigo is offline   Reply With Quote
Old 12-27-2012, 08:42 PM   #2
Hi Nicole, welcome to the forum.
The tub may have had insulation surrounding it to deaden some of the sound. Also, was the toilet's drain line re-worked? Did you previously have cast iron pipes and now you have PVC?
Old 12-27-2012, 09:09 PM   #3
lrngasigo
The toilet plumbing was not reworked. The shower drain was moved to the center of the shower...was a tub and so by the wall. I don't remember there being any insulation in any interior walls when we demoed. Of course there is on the exterior wall...but no plumbing there :-)
Nicole
Old 12-27-2012, 09:10 PM   #4
lrngasigo
Oh, and PVC toilet drain pipe.
Nicole
Old 12-27-2012, 09:35 PM   #5
I'd check the vent stack to the outside to make sure there isn't a partial blockage
Old 12-27-2012, 10:11 PM   #6
lrngasigo
You lost me at vent stack. I'll google it in a second, but, I don't think that is it, regardless. I think it is more a noise barrier issue than just the flusher. Voices and, er, sounds coming from the adjacent bathroom seem to come right through as well
Nicole
Old 12-27-2012, 10:15 PM   #7
lrngasigo
creative solution?
All right...what if I just cut a 'smallish' hole...and blew in some insulation? We need to have insulation put in our attic anyway. Why not just blow in this interior wall as well, to solve the problem? Any potential problems with insulation being blown in behind a tile job on an interior wall? Not normal, but, it might solve the problem?
Nicole
Old 12-27-2012, 10:23 PM   #8
Blown in will not have any adverse effects. Can't say how well it will work but its better than nothing.
Old 12-27-2012, 10:33 PM   #9
lrngasigo
Vent stack?!
Paul, you will never believe this. I think the loud flushing...and possibly even some of the carrying noises, could because of the vent stack. I googled it, saw a diagram, and a light bulb turned on in my sleepy brain. My vanity has not been installed yet, and, there is simply a stuffed piece of plastic in the hole between the wet vet and stack vent where my vanity will attach. There is probably a name for that. The flushing sound is probably being megaphoned right into the bathroom because there is no vanity/drain trap thingy and what not installed there? What do you think?
Nicole
Old 12-27-2012, 10:45 PM   #10
eblumer
EJ Flooring
Sounds possible to me, especially if there's no trap installed where the vanity will be placed.
Eric
www.ejflooring.com
eblumer is offline   Reply With Quote
Old 12-27-2012, 11:40 PM   #11
That plastic that's stuffed into the hole might not be sealing off the noise. Hold the palm of your hand over the "sanitary tee" fitting and have someone flush the toilet to see if the noise level drops. If so, go buy a plug from the plumbing department of any box store to temporarily seal it until the vanity is installed. It seals with a few twists of the wing nut and comes off just as easy. It'll cost about $2.
Old 12-27-2012, 11:48 PM   #12
lrngasigo
Definitely going to cover and flush in the morning to see if that helps with the sound. Thanks!
Nicole
Recognize this tile? + plumbing oopsie Houston Remodeler Professionals' Hangout 23 12-04-2010 08:47 PM
Tile Shower Plumbing Question rphillips Tile Forum/Advice Board 8 09-06-2008 10:01 AM
Remove & Reinstall Tile Wall Section for plumbing repair davidhmd Tile Forum/Advice Board 5 12-26-2007 09:09 AM
Need Tile Shower/Plumbing Remodeling Contractor in Central NJ cas Tile Forum/Advice Board 3 08-02-2006 05:32 PM
plumbing vs. tile problem garpascar Tile Forum/Advice Board 8 12-12-2001 08:26 PM
