Unread 01-09-2019, 06:57 AM   #1
Mineo_Maintenance
Replacing A Hole In Ceramic Tile Shower Wall
Good morning all,
I have a leak in the pipes of my shower at the handle valve. Master Plumber says I have to cut open the wall in order to source the leak properly. This is no problem to me.
The problem I'm having is how to replace the hole I cut into a ceramic tile wall. Can I just California Patch the wall underneath the tile then lay new tile on top?
Any kind of advice would help. This is at a residential facility, the tiles on the wall are small 1 cubic inch tiles. Anything appreciated, thank you.
John
John
Mineo_Maintenance is offline   Reply With Quote
Unread 01-09-2019, 07:04 AM   #2
muskymike
muskymike's Avatar
Hi John, welcome. Can this fix be done from the back side of the wall? If not I would cut the hole just big enough to get the fix done. After it is done you will need to patch the hole with CBU or Kerdi board then put the tile on and grout.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 01-09-2019, 07:05 AM   #3
Does the valve assembly have a cover/trim plate, John? I'd start by removing that to determine where the leak actually is. Alternatively, can you get to the valve from the other side of the wall just to have a look? The leak may not be where the MP thinks it is.
Replacing Shower Wall Tile onto Drywall Biddle111 Tile Forum/Advice Board 1 01-25-2017 01:30 PM
Patching a hole in shower/tub wall Serendipity Tile Forum/Advice Board 10 09-21-2007 01:28 PM
Newbie - Replacing Broken Wall Tile (found a trough around wall) heyitsme Tile Forum/Advice Board 7 07-08-2007 07:03 PM
Best way to cut hole in ceramic tile Verdeman Tile Forum/Advice Board 8 11-01-2006 08:55 PM
removing/replacing ceramic tile shower floor tilerookie Tile Forum/Advice Board 1 04-19-2002 06:35 PM
