Found usc_block_11 empty, added this: [CODE] [/CODE]
Old 08-06-2018, 07:02 PM   #1
jpb116
Marble shower tiles can use some help
I have a marble tile shower that has lost some luster of the years. Can the marble tiles be refinished / re-polished? Where would I begin to find the right professional to do this?
John
jpb116 is offline   Reply With Quote
Old 08-06-2018, 07:57 PM   #2
John I would start by having you add your location to your profile. There may be a pro close to you that can help.
It may just need to be stripped and resealed.
Old 08-06-2018, 08:01 PM   #3
jpb116
All set.
Central Connecticut
John
Old 08-06-2018, 08:23 PM   #4
Joe-Tile
To bad John, i was just there to build a steam shower for a contractor i used to do work for before i moved. Just a suggestion but have you tried to use an enhancing type sealer. Might be what your looking for without the expense of a more in depth solution. I know the couple times i looked into refinishing a countertop for customers the cost to hire a granite guy to repolish on site was not very cost effective.
Joe
3rd generation Owner of Joe Tile
Quality tile installation since 1948.
Joe-Tile is offline   Reply With Quote
Old 08-09-2018, 07:39 AM   #5
If you're going to enhance marble, try it in a small spot to see if it helps. Some marble enhances more than others and once you enhance, there's no going back. Most of the time I see this, a restoration company is needed to polish it. Just one of the reasons why marble isn't recommended in showers.
Is my marble shower floor wet under the tiles? AOKay Tile Forum/Advice Board 26 03-11-2015 01:26 PM
New never used marble shower showing wet tiles Hnyc Tile Forum/Advice Board 4 03-01-2014 07:27 PM
Marble tiles for a shower pan MangoMan Tile Forum/Advice Board 13 02-26-2006 01:03 PM
Marble tiles in a shower SPB Tile Forum/Advice Board 1 06-14-2005 12:04 PM
Best Grout for Marble Tiles in Shower tfratzel Tile Forum/Advice Board 3 02-22-2005 07:06 PM
