Unread 11-27-2009, 08:06 PM   #1
jeffg
concrete grinder
Can anyone recommend a good concrete grinder. Ive been havung to grind concrete floors with a 4in angle grinder. Would like to get something better and faster. A lot of the grinding is in small areas.
Thank You,Jeff
jeffg is offline   Reply With Quote
Unread 11-27-2009, 08:09 PM   #2
Davestone
Florida Tile & Stone Man
What kind of grinding, the whole floor,or just humps?
http://Davestonestile.com
Unread 11-27-2009, 08:09 PM   #3
Wayne67vert
Tile Contractor
Wayne67vert's Avatar
Send a message via AIM to Wayne67vert Send a message via MSN to Wayne67vert Send a message via Yahoo to Wayne67vert
Jeff, I use a 7in diamond wheel on a DeWalt 7 in grinder. Also have a dust collector collar attached to my shop vac to hold down the dust.
Wayne
Wayne67vert is offline   Reply With Quote
Unread 11-27-2009, 08:11 PM   #4
jeffg
mostly just humps
Unread 11-28-2009, 11:43 AM   #5
silvercitytile
silvercitytile's Avatar
the 7" cup wheel works great. i wish i had that dust collector.
Castillo Construction
Unread 11-28-2009, 03:17 PM   #6
Wayne67vert
Tile Contractor
here is the dust collector:
http://www.dustmuzzle.com/product_list.php?PCID=1
It works very good as until the filter plugs.
Wayne
Unread 11-28-2009, 07:15 PM   #7
Davestone
Those 7 inchers with dust collection are nice.But years ago i used one of these once, and it was the bomb...http://www.contractorsdirect.com/Con...oncrete-planer
Unread 11-28-2009, 08:07 PM   #8
MSLiechty
Bosch makes a concrete grinder that controls so much dust you will be hard pressed to believe your are grinding concrete Runs under $400 from amazon.
ML
Michael
_______________________________________
When I die I hope my wife doesn't sell my tools for what I told her I paid for them.
MSLiechty is offline   Reply With Quote
Unread 11-29-2009, 08:15 AM   #9
mossypath
mossypath's Avatar
The last floor I had to grind was a 250sg that was the worst I had run across . leveler alone would have put me 3/4 above the exterior door before tile so it was a grind and fill . With this floor (clean freaks in a finished kitchen ) I rented a dust collector from the depo and was real impressed . It had two switches on it and with both going you just about had to lift the grinder off the floor the suction was so good . Saved ware on my shopvack and all of my plastic was so clean I can reuse it . The price of the plastic was greater then the rental . For anything more than a few humps or a small bathroom I will do it again .
Tammara
mossypath is offline   Reply With Quote
Unread 11-29-2009, 08:28 AM   #10
jcsa
Tile Contractor
Makita Concrete Planer
Ditto on the Makita tool, They work so well i bought two of them. Gets it done fast and good, You have great control of what you are doing.
J.C.
JC
Certified Tile Installer # 26
Cox Tile, Inc.
jcsa is offline   Reply With Quote
Unread 11-29-2009, 10:23 AM   #11
Jim Doane
Custom Masonry Contractor
I use the bosch grinder and the dust deputy. www.dustdeputy.com
Jim Doane is offline   Reply With Quote
Unread 11-29-2009, 01:39 PM   #12
jeffg
thanks for all the help everyone
Unread 11-29-2009, 01:41 PM   #13
jeffg
Which one of dust muzzles do you use Wayne.
Unread 11-29-2009, 05:27 PM   #14
MNTileGuy
Central Texas Tile Guy
I've got a 7" Milwaukee, but I've had major problems with the dust collection shroud. The last one I got was called the "Dustie" (I think) off e-bay and it fell apart right away. Plus my shop vac filter clogs all the time and I never realize it until it's too late.
Maybe I need to invest in some of the products that have been listed...
Brad Bressler
Bressler Tile and Stone
www.bresslertile.com
Unread 11-29-2009, 05:46 PM   #15
dhagin
I've got this one and it works really well till the shop vac filters clog... seems there's a pattern here.
http://www.blastrac.com/en-us/pc-114...inder-vac.aspx
They sell the shroud seperately. It has a flip up edge for getting next to walls.
http://www.blastrac.com/en-us/pc-903-31-eco-shroud.aspx
dana
Need a good concrete grinder chase2000gt Professionals' Hangout 2 03-27-2008 09:27 PM
Vacuum suggestions for Bosch Concrete Grinder mbweppner Tile Forum/Advice Board 5 02-04-2008 01:15 PM
grinder madmax Professionals' Hangout 9 07-28-2005 07:38 AM
Grinder question LouS Tile Forum/Advice Board 5 03-02-2005 03:05 PM
