Unread 07-18-2021, 07:58 PM   #1
netrate
Corner Grout small holes - how to fix?
The shower I put in a few years ago has some little holes the size of a grain of rice in the corners. How should I go about fixing this? I don't know how much water is getting through, but I want to hopefully fix it before it causes issues.
David
netrate is offline   Reply With Quote
Unread 07-18-2021, 08:23 PM   #2
First off, industry guidelines are that any changes of plane or materials that are tiled should have a movement accommodation joint...IOW, that shouldn't be grouted, as grout is rigid. Now, some people grout it and don't have issues, but many do.
Second, a shower should not be damaged by water, even prior to the tile being installed. So, a gap in the grout should not be reason for a fault.
But, if you want to fix it, by trying to fill in the hole, go for it. If the hole isn't deep enough, grout tends to not stick, though. And, the color may not match new stuff versus old stuff.
Unread 07-18-2021, 08:40 PM   #3
netrate
After re-examing it, the hole is in the caulking where the vertical and horizontal walls meet. Knowing that, should I just try to add some caulking to the hole?
David
Unread 07-18-2021, 08:44 PM   #4
Are the corners grouted or caulked, David?
With what, in either case?
Unread 07-18-2021, 08:48 PM   #5
If it's caulked, you may need to cut the caulk out, clean up the joint, and recaulk. The hole likely has some crud in it, and applying some on top may not work well.
Unread 07-18-2021, 10:36 PM   #6
Shaklee3
Either way, you won't be fixing anything by caulking over it because the caulking wasn't your waterproofing to begin with. You have moisture behind the tiles already. The caulking is just there instead of grout so it doesn't crack from movement over time.
Cliff
Shaklee3 is offline   Reply With Quote
Unread 07-19-2021, 07:38 AM   #7
netrate
They are a bit squishy, so yes they are caulked.
David
Unread 07-21-2021, 07:30 PM   #8
netrate
So should I just leave it as such?
David
Unread 07-25-2021, 07:35 AM   #9
As long as those holes aren't weeping any water you could try to fill the holes with caulk, David, but no guarantee of success. The current caulk should be silicone, and new silicone tends not to stick to old, cured silicone.
Small bathroom - start in center or corner? mcfrosticles Tile Forum/Advice Board 1 03-27-2016 08:18 AM
Drilling small holes in porcelain tile jayeagle Tile Forum/Advice Board 12 08-31-2010 12:14 AM
sealing kerdi corner holes? Ryanlearnstile Tile Forum/Advice Board 22 11-26-2008 07:05 AM
Fix small chip in corner of porcelain tile rambo1224 Tile Forum/Advice Board 4 11-24-2007 09:59 PM
Cement slab prep when it has small holes in it Unregistered Tile Forum/Advice Board 1 01-18-2005 11:00 AM
