Unread 06-26-2021, 06:31 AM   #1
anonymous_1977
Fireplace finishing
Folks - I have recently contracted with a fireplace company to build a gas fireplace. It will be installed in a corner as shown in the picture below with the sheetrock showing the size of th box. The whole area will be framed and sheetrocked. They can do stone work using cultured stone on the front but nothing on the top as they don't have any material that looks like a right angle.
Now I have a concern that should they use cbu instead of sheetrock for stone to adhere well and this is the response I received. I already have a contract with them, so I cannot back out now. Is this response ok in using sheetrock?
When doing the stone, we are able to install it over the sheetrock, and the non-combustible board that comes shipped above the top of the unit.* Before the stone is applied, the mason would apply a mesh guard that is mortared on to the wall.* After that, each piece of stone is individually mortared on to the wall.*
Sent from my GM1917 using Tapatalk
John
anonymous_1977 is offline   Reply With Quote
Unread 06-26-2021, 09:15 AM   #2
Welcome A....
You might want to check with the manufacturer of the stone product you've selected to see if they have any substrate and material requirements for installing their product.
But FWIW, thinset mortar will stick to drywall quite tenaciously.
Unread 06-26-2021, 09:30 AM   #3
anonymous_1977
Hello just so that I understand, are you saying the approach the fireplace company gave is sound? What I mean is will the stone weight pull down and collapse the sheetrock?
John
Unread 06-26-2021, 10:16 AM   #4
Unless the manufacturer has their special requirement (why Dan suggested asking them), the drywall is more than sufficient for the weight. It is very common to install additional screws to secure the drywall, though.
Unread 06-26-2021, 10:29 AM   #5
anonymous_1977
The finishing section of the manual has the below.
John
Unread 06-28-2021, 10:16 AM   #6
anonymous_1977
Originally Posted by ss3964spd View Post
Welcome A....
@Tool Guy - Kg the installer is going to use cement board based on my request. Would that be good?
@Tool Guy - Kg
John
Unread 06-28-2021, 10:50 AM   #7
anonymous_1977
Installer is willing to use cement board. Is that ok?
John
Unread 06-29-2021, 05:03 AM   #8
anonymous_1977
Hello all - the fireplace company is willing to do cement board at no extra cost. Is this a better alternative than sheet rock?
John
Unread 06-29-2021, 06:46 AM   #9
Sure, either one will work.
Unread 07-02-2021, 03:46 AM   #10
anonymous_1977
Need some fireplace finishing advise
Hello all - the fireplace company can finish the front of my fireplace with cultured stone. It will cost about $50/sq ft installed for about 16 sq ft (they don't reduce the cost for the fireplace opening). So this will run me about $900. Is this a good finish or should I go for real stone? Also since this is a corner fireplace they do not have any material to cover the sheetrock on the top. Any recommendations for the top as a DIY project or maybe even use someone? The picture should clear up what I mean by the top.
The link to cultured stone is www.culturedstone.com
John
Unread 07-02-2021, 07:02 AM   #11
John, please don't start new threads with the same project questions. If you don't think you're getting timely response, just make another post to your thread to bump it to the top of the queue for attention.
It's purely an aesthetic consideration. Don't know what you/they might mean by "cultured stone," but if it's the same "cultured marble" we frequently see in shower constructions, it may or may not have the look you want on your fireplace.
Unread 07-02-2021, 08:08 AM   #12
anonymous_1977
Thanks. Do you know what happened to the responses on the new thread? It had some important links that I need.
John
Unread 07-02-2021, 08:10 AM   #13
anonymous_1977
I provided link above to the type of stone. Hopefully that helps.
John
Unread 07-02-2021, 10:08 AM   #14
There were no responses to the new thread when I combined it here, John.
Unread 07-03-2021, 01:01 AM   #15
Davy already answered your drywall/cement board question, so I’ll respond to your latest:
I’ve understood “cultured stone” to mean a man-made version that has been cast to mimic the look of real stone. Either is fine. Whichever looks best to your eye. But I’m not sure I’d hire a contractor who will leave the top for you to finish. I don’t think it’s going to look finished and seamless if the top is put on later.
Finishing Help! jjhugel Tile Forum/Advice Board 12 02-23-2019 07:43 PM
Finishing Stone Fireplace Mthalman5513 Tile Forum/Advice Board 2 01-05-2017 01:00 PM
Finishing CBU edge of Fireplace opening Stoney2 Tile Forum/Advice Board 3 08-15-2012 01:11 PM
Finishing gap brnt999 Tile Forum/Advice Board 30 03-16-2008 12:31 PM
tub re-finishing fineline Professionals' Hangout 2 01-26-2005 05:43 AM
