Unread 06-02-2021, 04:51 AM   #1
Cactus_King
Shower drain installed flush with subfloor without flange
After tearing out mud bed I found out the drain is flush with the concrete floor. There's no flange, just a threaded 2 inch hole that the drain screws into. Will I be okay with doing the pre-slope, then gluing or puttying around the threaded drain before I put down my pan liner and installing the mud bed or do I need to jackhammer it out and start again?
Cactus_King is offline   Reply With Quote
Unread 06-02-2021, 07:40 AM   #2
Welcome, Shawn,
Pretty sure the answer is no. If you intend to install a presloped mud bed, then liner, then final mud bed you need to use a drain assembly that's compatible with the liner; a clamping drain assembly and the one you've got, well, aint.
Unread 06-02-2021, 04:09 PM   #3
fabian55
Hi Shawn, I might be wrong as I am not a professional and also ask questions on here, but there are adapters you can use so you don't have to jack hammer anything out. So example, a linear drain will have an adapter that screws in just like that, a traditional drain, if im not mistaken, has adapters to screw into that as well, just need to purchase it separatly
Use the adapter so that you can have the flange, do the first slope, run the liner and do the second layer on top of the liner.
PS: I would recommend you do research and first determine what type of waterproofing system you will use, traditional or bonding as they have different methods and drains as well. Example, you won't be able to use a bonding drain with the traditional method etc..
Fabian
fabian55 is offline   Reply With Quote
Unread 06-02-2021, 04:33 PM   #4
Welcome to the forum, Shawn.
I'm not sure you have the proper drain for a tile shower. I can't see the lower part, so I can't say one way or the other.
I'd break out the concrete around the drain to see what's below.
Unread 06-02-2021, 04:35 PM   #5
Fabian, as Dan pointed out above you cannot use a traditional shower receptor liner with that drain. It's got no mechanism for clamping the liner and I know of no adapter that will correct that. It's gotta come out, and that would also be true if Shawn decides to use a bonding flange drain and direct bonded waterproofing membrane.
Unread 06-02-2021, 04:55 PM   #6
fabian55
CX, you are correct, I looked at the adapters online and its for example, Linear Drain Adapter for flanges already in place, or Adapters to reduced size etc, but they all have the flange already installed. So yes, seems it would have to be removed..
Fabian
Oatey shower drain not flush with plywood subfloor rostonn Tile Forum/Advice Board 8 01-04-2021 06:54 PM
Shower drain flush with concrete floor- help! MobileMarch567 Tile Forum/Advice Board 28 01-27-2020 09:16 AM
HELP Please. Shower drain isn't flush with tile. Allen279 Tile Forum/Advice Board 5 06-11-2009 10:39 PM
Can the toilet flange be flush with top of floor? sarecco Tile Forum/Advice Board 4 08-03-2007 09:43 AM
HELP! Building Shower pan - Lower flange is not in flush with the floor tiiger Tile Forum/Advice Board 8 01-04-2006 09:27 PM
