Unread 04-25-2021, 01:38 AM   #1
krc
Karl
12x24 wall tile, grid pattern... carry cut thru?
Hi ...
Looking at a grid pattern (horizontal) for a bathroom, 12x24 on wall. Floor will be 24x24 on diagonal set. Would carry the cut through to the next wall? Say my back shower wall is 5 ft, center of the wall is also the grout line , then I would have a 6" cut on either side that goes into each corner.
Would you carry then 18" to the next wall or just "start over"? I can see if you offset 1/3 you would want to carry cut piece around the corner, but not sure on a straight lay like this.
Or would you go 24" 24" 12" into a corner and then ?
(I could do a 1/3 offset but I think with the large format tile on a diagonal in a fairly small bathroom, it would be too busy. Vertical grid (24" up) might make more sense as that would be more even (5'/12") and and scribing probably not noticeable on the corner turn. But not sure I am a fan of vertical... but if this makes more sense I could do it.)
KRC
Karl
krc is offline   Reply With Quote
Unread 04-25-2021, 04:50 AM   #2
pls
I am working on a shower right now using 12x24. I like the look of 1/3 offset and I carry the cut to the next wall. However I will make adjustments. In my case if I would have carried exactly 6 on to the short wall I would have had a sliver at the other side so I used 7.5. You do not notice the difference
Phil
pls is offline   Reply With Quote
Unread 04-25-2021, 06:47 AM   #3
I was thinking the same as Phil, however you decide to do the back wall, you can slightly adjust the end walls to avoid a sliver out where the tile meets the paint. Small adjustments won't be noticeable and helps the looks of the job.
Also, on the back wall, there's two ways to center the layout. Either center a grout joint in the wall or center a tile. Do some measuring to see what size cuts you'll have before deciding.
Unread 07-21-2021, 11:19 PM   #4
krc
Karl
"Diagonal" layout at 20 degrees?
Just curious if anyone ever lays out at something other than 45 for a diagonal layout? I am in installing 24x24 tiles in a fairly small bathroom. Key "width" is 52 inches (edge of shower base to toe kick at vanity). I just was playing around trying to maximize the full tiles simply as I like the larger look. But, it is not diagonal in the sense that "point to point" obviously do not line up. I am worried this would be too odd and possibly feel out of place in the long run. The walls by the shower area will be tiled w/ 12x24 set vertically with a 1/3 offset.
Just curious as all I ever see is a straight 45 diagonal layout, and I did the same with 12x12 tiles for similar bathroom....
Karl
Unread 07-22-2021, 07:30 AM   #5
Just In Tile LLC
Just In Tile LLC's Avatar
I've seen some other degree layouts in a office building, never have done one. The only think I can think of is man the cuts would be brutal to mark accurately.
My drycutter has a 15° and 30° angle setting but I've never used it. Maybe the cuts are easier to mark than I think but couldn't imagine a complex cut at those angles, would slow me down big time.
Justin
Unread 07-22-2021, 07:54 AM   #6
Feel out of place to whom, Karl? If the owner of the bathroom likes it, and if you're willing to put in the time to do the pattern, I'd say it's just right.
Unread 07-22-2021, 11:24 AM   #7
Tile & Stone Guild
King Of Tile
Personally I loathe a square tile on a brick. Doesn’t make sense to me, but as Cx stated it’s your house do what makes you happy. I’ll also add with a small floor like that you won’t pick up much of a pattern with that big of a tile, I would keep it straight and simple.
Jeff
Unread 07-22-2021, 06:32 PM   #8
thuffner3
Ive used a 30/60 degree layout, Calculations are extremely easy.
The Hyp is exactly 2 times the rise of the short side.
Neil Jackson, from Cincinnati, Ohio
Her contractor said she could have it installed today.
thuffner3 is offline   Reply With Quote
tile pattern help for 12x24 18 sq and 12 sq haeffnkr Tile Forum/Advice Board 1 01-29-2014 06:38 PM
12x24 tile - Herringbone pattern ? mag1 Tile Forum/Advice Board 34 05-13-2013 09:55 PM
Need help setting up grid pattern general Tile Forum/Advice Board 6 04-17-2013 10:24 PM
Diag pattern carry through Autoplay Professionals' Hangout 18 01-11-2010 09:38 PM
Pattern Grid Layout Help DougR Tile Forum/Advice Board 5 11-21-2008 02:45 PM
