Unread 07-31-2015, 06:39 AM   #1
mark999
contractor installed blue drywall in shower
Is blue board drywall (moisture resistant) acceptable as a substrate ? Stall floor will get deck mud with latticrete membrane and walls(blue board) will get hydroban applied with using a thickness gauge. Tile is honed limestone on a mesh sheet in a chevron design 1.3 sq. ft. per piece.
Mark
Mark
Unread 07-31-2015, 07:21 AM   #2
Apparently acceptable to your Contractor, Mark. Not likely acceptable to your local building code. Not acceptable to the waterproofing membrane manufacturer.
Originally Posted by Mark
Stall floor will get deck mud with latticrete membrane and walls(blue board) will get hydroban...
Hydroban is a Laticrete membrane.
Unread 07-31-2015, 08:37 AM   #3
While drywall is an acceptable substrate for hydroban, there is an exception for wet areas where hydroban is to be installed only over ceement board.
problems with contractor-installed tub surround LBQns Tile Forum/Advice Board 5 01-20-2012 11:08 PM
Blue drywall / sheetrock Hammy Professionals' Hangout 7 03-26-2009 08:06 PM
Has anyone here seen or installed Labradorite Blue granite before? Indpowr Professionals' Hangout 8 04-18-2008 06:50 PM
Think contractor installed incorrectly Been Taken Tile Forum/Advice Board 10 01-06-2005 11:53 PM
Contractor Installed Hardibacker Wrongside Out Chris D Tile Forum/Advice Board 12 08-31-2004 06:41 PM
