Old 03-03-2008, 02:38 PM   #1
tileguy88
Tile Man
Radius walls inside shower
I'm planning a new shower for my home and thinking of building the corners to about an 8" inside radius. The tile will be 1" glass mosaic. I'll be using Kerdi on the walls. Hoping someone will know of a way to achieve this type of a finish. My first (and only, so far) thought is to mud the corners. My experience with mud to date is building sloped shower floors. Is the procedure the same? Any other thoughts??...
Ceramic Tile Solutions LLC
Eagan, MN
tileguy88 is offline   Reply With Quote
Old 03-03-2008, 03:19 PM   #2
conceptsplus
Conceptsplus- Randy Gilmore
conceptsplus's Avatar
Hey Brian, Walls are different than floors. I hate to say this, but Wedi has a panel designed to contour radious walls. There may be others out there. I just am not aware of any. Since your using kerdi and people in here say it's OK to use sheetrock under kerdi. I suppose you could wet a piece of sheetrock and form it to fit your radious.
Randy Gilmore
Natural Stone Contractor - Springfield, Missouri
Website needs updates- be back soon.
conceptsplus is offline   Reply With Quote
Old 03-03-2008, 03:24 PM   #3
Brad Denny
Tile Contractor Nashville, TN
Brad Denny's Avatar
Mud would be the way to go. If not, PermaBase sells a flexible CBU called PermaBase Flex , go figure.
Brad
Old 03-03-2008, 03:50 PM   #4
conceptsplus
Brian, Brad's right about the mud. Generally when people ask me if they should mud the walls, I answer with a question. What is the pupose of a scratch coat?
If they know the correct answer, I tell them go for it! Usually those with the answer don't ask that question. I'm just trying to simplify this for you. Never heard of the flexable permabase but sounds like a good possibility! Incorporate it with the rest standard permabase, then kerdi.
Randy Gilmore
Old 03-03-2008, 06:04 PM   #5
Dave Ashton
Engineer/Tile Contractor
Here is a project Im working on at my house with a radius. Radius is two layers of 1/4" rock glued and screwed to the framing. After stapling the lath up I attached it to the framing with roofing nails. I cut the "wall" screed to accomodate my straight edge plus 1/2" of mud, opposite side the radius minus a 1/2". First time I had ever done an arch, seemed to work ok. Patience is the key...lots of mud in the tub as you go. I floated it in two days because I didnt want to screw up the vault float while doing the back wall. I didnt finish the right hand wall with the first float because, well, I ran out of mud and I dont have "Albert." Hope this helps...lots of fun that is for sure!
Dave Ashton is offline   Reply With Quote
Old 03-03-2008, 06:10 PM   #6
Dave Ashton
I waterproofed the whole thing with Hydro Ban.
Old 03-04-2008, 06:09 AM   #7
tileguy88
Tile Man
Ok, so my plan is to go with the mud corners. Is it possible to get the mud to feather edge for a smooth transition back to a flat wall? Or should I plan on a skim coat or 2 of a patching compound like Ardex? I'd really like to drywall the entire shower, and mud only the corners. I'd appreciate a basic walk-through in the technique for mudding the corners. Thanks, guys.
Eagan, MN
