Unread 04-22-2011, 12:57 PM   #1
Papethova
Los Angeles area looking for a kerdi pro
Im looking to install a proline drain and want to use the kerdi system.
Proline comes with a noble liner attached around the flange, is it compatible with the kerdi? Can I just kerdi up to the drain and overlap the entire noble membrane with the kerdi?
Also, proline suggests notching the subfloor plywood and just dropping the drain in then using their foam preslope. No real way to secure the drain and it sits on the plywood (no mud or 1.5" depth). Does this sound right to anyone?
Finally, Id like to place the drain along the threshold and threshold wall spanning the entire shower length (sloping from the back of the shower down to the drain approx 45 inches at 1/4"/ft). Then have a slight slope from the dry area to the drain (doorless/curbless). Does this comply with California code? I have read about a 2" drain to curb height, obviously that doesnt exist here.
Allen
Papethova is offline   Reply With Quote
Need Kerdi tile contractor in Los Angeles John777 Professionals' Hangout 18 06-06-2009 06:05 PM
Ditraset/kerdiset in Los Angeles area FireWrks7 Professionals' Hangout 16 03-24-2008 10:44 PM
Looking for tile pro in Los Angeles area FireWrks7 Professionals' Hangout 2 12-11-2007 05:15 PM
Los Angeles - Kerdi Scrap Needed o2manyfish Tile Forum/Advice Board 6 10-10-2006 07:42 PM
Good Sources for Granite Tile in Los Angeles Area? BobF Tile Forum/Advice Board 16 04-04-2003 01:23 PM
