Unread 10-07-2020, 08:05 PM   #4771
John you should know this one. Dutchmans were also used above doorways when mud cap (A4402) were used on the right and left side of the door jamb. Therefore you had full tile on each side and you would do to Dutchman first tile in so it would create a full tile look above the doorway.
Unread 10-09-2020, 05:25 AM   #4772
Yeah, I'm aware of that but never had a need to do it. We always used A-4200 around the doorways with cuts against the corner pieces (AN-4200). On occasion, I did use double cuts of bullnose (cut edges facing each other) in the middle.
Unread 10-09-2020, 05:56 PM   #4773
Gozo
I had to share
My wife and I stayed at a B&B and being the tile snob you’ve all made me into; I had to share this. The place was immaculately kept and we had a fun time. The hosts have been fixing the place up over the years and described it as “a bad Addams family house” when they moved in. The tile work is original and has been patched in places by them. Submitted for your approval...
Jeff
Unread 10-23-2020, 12:48 PM   #4774
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Jeff, wow. That's bad.
Currently tasked to replace entry door. Had to remove a few tiles to make the new threshold fit. Tile is about a year old. Looks like a b+ maybe a- install visually. But....
These tiles came up very easily. Assuming tiles were wet during install. Other coverage issues also.
If anyone catches this in the next hour and has an answer. This subfloor that will be under the threshold has a hump in it. It. Thinking about building a dam or form at at the edge and pouring liquid background under that area to level it out. Thinking that will provide a better and level substrate to set the door on. Make sense?
What's your fix? Shims?
Oh, and i got the jamber kit
Sent from my SM-G965U1 using Tapatalk
Travis
It's just a clever handle.
Unread 10-24-2020, 04:57 AM   #4775
CaliGrown
CaliGrown's Avatar
Nice level kit!! Perhaps there will be a floor job in your near future...
Plywood:
• plane it down
• prime and SLU
Concrete:
• prime and SLU
* only cup wheel the hump down if it’s a wonky one.
Christopher Machado
1 (916) 990-1751
Unread 12-02-2020, 11:43 PM   #4776
Mmmmmmmmm.....painted floor tile in a commercial restroom.
Unread 12-25-2020, 11:28 AM   #4777
Who puts a white receptacles plate on a beige receptacle?
Unread 12-25-2020, 12:14 PM   #4778
CaliGrown
CaliGrown's Avatar
SMH beige on white. So long as it’s grounded..
Christopher Machado
1 (916) 990-1751
Unread 01-02-2021, 07:50 AM   #4779
Tile & Stone Guild
King Of Tile
Here is what I ripped out of a never been used shower. Waterproofed the clamping ring, weep holes, bolts etc. Also they used 2 pan liners and no pre slope. 2 years old and the waterproofing was still wet under the ring sandwich.
Jeff
Unread 01-05-2021, 04:50 AM   #4780
CaliGrown
CaliGrown's Avatar
Two liners. Intention/Thoughys “double the protection, slow down any leaks from the wallboard screws and staples.”. Actuality is that it’s twice as likely to fail. Lol. Never come across a double liner, yet...
Christopher Machado
1 (916) 990-1751
Unread 01-05-2021, 09:34 AM   #4781
Two liners = fails twice as fast.
Unread 01-20-2021, 06:03 PM   #4782
Shady at Best
Tyrone shoelaces
Tearing out a tile floor after a water leak. What percent coverage would this be? 55%-65%?
Travis
Unread 01-20-2021, 11:57 PM   #4783
My eyes aren't what they used to be, but I don't see any mortar on the piece that is broken off, nor on the hardibacker where it was.
Unread 01-21-2021, 03:56 AM   #4784
A good grout job should be able to make up for a lack of pesky setting mortar. Plus, plus, they used Hardi...so there’s that.
Unread 01-21-2021, 07:16 AM   #4785
CaliGrown
CaliGrown's Avatar
Lol, musta got late/tired and had it grouted during a dry-fit
Christopher Machado
1 (916) 990-1751
Absolute worst tile finishing job pitterpat Professionals' Hangout 17 04-02-2007 07:12 PM
worst of the worst... botched jobs Dan O'Connor Tile Forum/Advice Board 5 02-22-2007 03:21 PM
best and worst tile saw in $300-$500 range LinLee Tile Forum/Advice Board 9 01-30-2006 01:50 AM
best and worst tile saw in $300-$500 range johnnyaico Tile Forum/Advice Board 10 01-27-2006 03:05 PM
The worst job................ opiethetileman The Mud Box 6 10-08-2004 10:48 PM
