Unread 08-24-2006, 01:20 PM   #1
Buck
Polished trav with "water marks"
I have just finished installing crema marfil travertine on a bath floor. When light reflects of the stone at an angle some of the tiles have what appear to be water marks. I have tried to remove them with stone techs stone cleaner and also reapplied a tile lab surfaceguard penetrating sealer and wiped it off immediately. I had sealed the tile with this sealer before installation. Neither of these approaches did much to help. The tiles were installed with custom building products marble and limestone medium set mud and grouted with custom building products unsanded grout in 1/16" grout lines. Can I do anything to fix this problem. Thanks.
Buck
Buck is offline   Reply With Quote
Unread 08-24-2006, 02:17 PM   #2
Stonehenge
Mineral Polishing Education Specialist
Stonehenge's Avatar
Hi Buck,
Crema Marfil actually is a compact limestone and travertine is a travertine.
That being said you may have geodesic voids that were filled at the factory or a different mineral configuration or chemical damage.
Michael of Stonehenge
Michael
Stonehenge is offline   Reply With Quote
Unread 08-24-2006, 02:38 PM   #3
Buck
Hi Michael
They are definitely not voids, but a water mark looking rings that doesn't have any relief, i.e., you can't feel them by rubbing your finger across. They range from dime to quarter size. It almost looks as though some mud sat on long enough to stain it, however, I did seal before installation and tried to get the mud off right away. In any case, do you or others think I can remove them? Also, it occurs on just 2 or 3 tiles, not the entire room.
Unread 08-24-2006, 02:43 PM   #4
doitright
doitright's Avatar
Hi Buck, Welcome!
Are these spots dull, when you look at them in the light from an oblique angle?
John Koessler
Unread 08-24-2006, 02:49 PM   #5
Buck
Hi John
The ring is dull. The interior is normal. They occur over the natural pattern of the stone. They are not part of the fossil pattern or veins in the stone.
Unread 08-24-2006, 03:17 PM   #6
Stonehenge
Stonehenge's Avatar
Hi Buck,
If what you observed are ring marks then you may have chemical damage caused by setting a bottle of something atop your natural stone.
If you have the capacity to post pictures then please do.
Michael
Unread 08-24-2006, 06:41 PM   #7
Steven Hauser
STT Owner
Steven Hauser's Avatar
Hi Buck,
You have two approaches.
1) Use a razor blade at a 22.5 degree angle and see if the film will scrape off. Carefully going from 22.5 to 45 degrees in all directions.
2) reapply the impregnating sealer and let dwell for 2-4 minutes and then wipe off completely.
If this doesn't help then I agree with Michael, you probably have an etch that would need to be repolished.
Clean
Sealed
Safe
STT Sealers with Attitude!®
Unread 08-24-2006, 07:51 PM   #8
jvcstone
Stone Carver
Did you set your coke can on the tile while you were setting it??? that could make a ring like you describe. Be aware that your polished limestone will be suseptable to all sorts of acid etches.
JVC
Come visit me at www.hunkerdownranch.com
-- John VanCamp
we should not accept something as true until it has been officially denied!
jvcstone is offline   Reply With Quote
Unread 08-24-2006, 08:18 PM   #9
doitright
doitright's Avatar
Originally Posted by Buck
They range from dime to quarter size. In any case, do you or others think I can remove them?
Hi John
Small coke can, huh?
Hi Buck
Since you can't feel them, I would try some Aqua Mix Renue on them.
John Koessler
Unread 08-25-2006, 06:58 AM   #10
Buck
Thanks for your help-One last thought
After sleeping on this issue for a night, I think I know what caused these marks. It was very hot on the days that I mudded the tile, and I was sweating profusely. These may be sweat drops that I didn't see to wipe up as there were also some water drops from cleaning off mud on some tiles. If sweat is acidic it may somehow found its way past the sealer. Incidentally, nothing other than water, mud, sealer, and sweat touched these tiles: no drinks. I have a cut waste piece with some of these marks that I will use to experiment. Thanks again.
Unread 08-25-2006, 11:04 AM   #11
doitright
doitright's Avatar
Hi Buck
Let us know how it comes out.
John Koessler
Unread 08-25-2006, 02:10 PM   #12
MasterGranite
Crema Marfil is Marble and will etch with any and all acids and other stuff like most cleaning chemicals. Be sure to use a cleaner that is appropriote for Marble and Limestone. Marble is related to Limestone in that it started as sedimentary rock. However the Limestone was put under pressure and high temperature in the earths crust and molten rock was created. This molten rock chrystalized durring the cooling process. The new rock that formed was marble. So they are related but they are not the same stone. Marble is usually harder and much more dense than limestone. It could be that a few tiles actually were marked prior to installation somewhere. I've not seen a polished finish get etched by sweat, beer and lemmon yes (mixed together) but not sweat. Think neutral cleaner. Here's the real question tho. The spots are not very visible I bet, and since the tile is on the floor, it won't take long before there are other marks on the tile and the original ones will just blend in. Oh and be real careful of the cleaners you use, not just on the floor but other places in the bathroom!! If SOMEONE spills some, ain't nothin gonna stop the etch sans a plastic drop cloth. Oh and hey ya better watch your step getting outta the shower... polished marble is very VERY slippery when wet.
Bob Brown
b.bobrown@verizon.net
Volpetile.com
215-957-6497
MasterGranite is offline   Reply With Quote
Unread 08-26-2006, 07:05 PM   #13
claycarson
Commercial Cleaning and Maintenance
Almost certainly they are acid etches from a bottle.
Sealer would not be able to prevent this.
Good news is, this is routine with marbles and travertines. It can likely be polished out.
On the sample piece, etch it with some lite dilution of vinegar and water, then compare. Try to polish with paste first, maybe all that's needed.
Clay
www.tileboston.com
claycarson is offline   Reply With Quote
Unread 08-27-2006, 07:29 AM   #14
GraniteGirl
Ms. Makita
GraniteGirl's Avatar
Send a message via Yahoo to GraniteGirl
If the tiles etched with sweat, imagine what it would do with shampoo, toilet cleaner, urine, perfume or any other product found in a bathroom.
My advice to you/homeowner would be to have the tiles honed and enhanced to alleviate this problem in future. Polished limestone as a rule is not a good choice for a bathroom. (and this is now besides the fact that most folks here like to call it "Crema Landfill")
Adriana
www.IslandSoapstone.com
Relax - it's a rock! What could go wrong?!
GraniteGirl is offline   Reply With Quote
