Unread 03-07-2020, 12:05 PM   #16
It is kind of odd that it would run all that way back from the weep hole and drip a couple of inches from the wall. I would think it would continue and run down the wall.
Unless that spot was cleaned.
Unread 03-07-2020, 01:57 PM   #17
KestonDrip1
I just got out the level and you guys are correct about the top mud bed being sloped towards the drain, but the frame itself is pretty level with a very slight lean towards the back corner.
Welp, I was hoping it was just a matter of needing to change my cleaning products and routine, but it appears to be a deeper issue. Should I worry about the frame itself not being sloped towards the drain if I go with a topical solution such as Redgard?
I've also have a tiler coming out for some other projects in the next month or so, so will run it by him as well.
Keston
KestonDrip1 is offline   Reply With Quote
Unread 03-07-2020, 02:18 PM   #18
No, don't worry about the frame's orientation, Keston, Just waterproof the properly sloped top and move on. The seat will likely last longer than you will.
How old are you now?
Unread 03-07-2020, 03:53 PM   #19
It would be nice if they build the corner benches (well, all of them) with a bit of slope to them. All of the corners are welded to a 90-degree angle, so to get slope, you have to finesse things.
Unread 03-08-2020, 12:57 AM   #20
If you’re considering the partial (but likely effective) remedy of removing the seat tiles, waterproofing the exposed mud with a surface waterproofing, and re-tiling...
You may want to consider simply installing a single piece of solid-surface material over the existing tile on the top and another for the front of the bench. There are multiple thinset mortars that can be used to set the solid-surface material directly to the tile. And then silicone all the joints. I think it would be equal in effectiveness.
Possible weep hole problem ticktock Tile Forum/Advice Board 1 03-17-2010 12:40 PM
Weep hole question davenkell Tile Forum/Advice Board 33 03-14-2009 09:00 PM
Weep hole trick Knyte260 Tile Forum/Advice Board 4 02-06-2006 01:01 PM
weep hole question -- above/below webmastercts Tile Forum/Advice Board 2 02-09-2005 12:52 PM
weep hole question bwall76 Tile Forum/Advice Board 5 06-30-2004 08:05 PM
