Unread 06-20-2015, 07:57 AM   #1
Shoooe
Flexcolor CQ advice
I'm using Flexcolor CQ with glazed ceramic wall tile. I'm finding it pretty difficult to get the product on the wall and work it into the joints without a majority falling on the floor. The work I completed yesterday looks great today and hardened up nicely but half of the bucket ended up on the floor. I'm using a molded rubber float (directions call for medium to hard rubber float). The grout just seems too loose (especially compared to previous DIY experience with traditional grouts). I've used CQ on floors with great results but wall is proving to be tricky. Any advice?
Dustin
Shoooe is offline   Reply With Quote
Unread 06-20-2015, 09:35 AM   #2
Dustin, if you'll type Flexcolor CQ into the Advanced Search feature and ask for Titles you'll find some threads of discussion on the product, including one very in depth thread in the Hangout. Should answer any question you might have about using that product.
This for your Kerdi Shower?
Unread 06-20-2015, 06:12 PM   #3
nelsonkoehn
showers & more
nelsonkoehn's Avatar
One thing I find very handy in a shower; tape a piece of plastic on the floor. The grout will barely dry and can be picked up and reused.
As far as getting it on, it's all in the way you work your float. Comes with time!
Nelson
tile.nkoehn.com
nelsonkoehn is offline   Reply With Quote
Unread 06-20-2015, 06:31 PM   #4
Have you stirred the bucket contents before use ?
Unread 06-21-2015, 02:13 PM   #5
Shoooe
I did stir the contents but still very loose--again, the consistency was great for floors but a little bit more difficult on vertical applications. I'll definitely give the plastic a try and appreciate the tip. CX--I'll take a look at that thread in the hangout. I haven't ventured to that part of the site so that should definitely be new info for me. Thanks again for all of the help.
Dustin
Unread 06-21-2015, 02:42 PM   #6
Also work in small areas maybe 2 feet by 2 feet at the most before starting the cleaning procedure
Mapei Flexcolor CQ nelsonkoehn Professionals' Hangout 423 04-01-2019 09:00 AM
HELP Pls! Flexcolor CQ Mapei- glass, metal and stone tile? curligirl Tile Forum/Advice Board 1 11-25-2014 11:33 AM
Need a bucket of Flexcolor CQ Colabear Professionals' Hangout 4 11-04-2014 12:57 PM
Quartzlock 2 or mapei flexcolor cq. Recommendations? TREY HERRIOTT Professionals' Hangout 5 08-08-2014 10:09 AM
Advice on 'bad advice" F16fixer Tile Forum/Advice Board 8 12-18-2011 11:17 PM
