02-13-2013, 03:15 PM
#31
Jack of all trades, master of none
If it were my project I'd really try to find a drop-in style tub that would work in the area available rather than trying to frame around the front of a apron-front tub.
Click here: Drop-in tubs w/ three-sided flange
02-13-2013, 06:00 PM
#32
Hi Rob,
I agree with Pete. I think trying to tile the front of a standard tub will look cheesy.
02-14-2013, 08:57 PM
#33
Agreed, if I can't find a tub with the removable skirt and lips on sides and rear I won't do it. The thing is I've seen pictures of it done and wonder how the long term effect was.
Rob
02-17-2013, 01:13 AM
#34
Redgard or Hydro Ban?
Which liquid membrane do you prefer and why?
Rob
Rob
02-17-2013, 08:19 AM
#35
Senior Contributor
Laticrete, the makers of Hydroban have an excellent warranty, great people working for them, and the most excellent customer support.
Paul 1
02-19-2013, 10:18 PM
#36
Any negatives to using Redgard? Where I live, Hydro Ban is twice as much.
Rob
02-19-2013, 10:21 PM
#37
Nothing at all wrong with RedGard if it's applied per the manufacturer's instructions.
02-20-2013, 12:50 AM
#38
CX, is there any specific step that I need to pay close attention to? I've read and seen the video.
Rob
02-20-2013, 09:33 AM
#39
Rob,
I don't mean to sound glib, but follow all of the steps. When using liquid membranes the thickness of the application and curing time is critical.
02-22-2013, 02:41 AM
#40
Cutting 1/2" Hardibacker
How do most of you cut your 1/2" Hardibacker? I hear from some people that scoring and cutting the 1/4" is fine but the 1/2" is hard. I think I need a carbide blade for that. Saw? I heard that saws create a lot of dust and aren't good for the saws themselves.
So, how do you guys do it?
thanks!
Rob
02-22-2013, 07:51 AM
#41
I haven't used Hardie board in a while, but this little tool helps to score and snap it. It does help to make a few passes with it before trying to snap it. I've also used a Sawzall with a cheap blade I don't mind ruining; less dust than a circular saw.
I did use the new Wonderboard Lite on my bath project and was able to score the 1/2" board with a utility knife and snap it just like drywall.
02-25-2013, 01:08 AM
#42
Thanks Pete.
Rob
02-25-2013, 01:11 AM
#43
Removing vinyl floor adhesive
I'm removing the vinyl floor and want to know what you guys use to remove the adhesive and paper backing? I have no problem removing the vinyl but I got some paper and adhesive scatterd around now. I've read that some use heat guns and other use an adhesive remover solution. Any suggestions?
Rob
Rob
02-25-2013, 01:50 AM
#44
Wood floor or concrete or ??? Can you post some photos?
dana
02-25-2013, 08:51 AM
#45
Here is how bad a tile front looks . This whirljet tub has got to go.
Teddy
