Unread 01-03-2010, 07:54 PM   #1
-Christopher
-Christopher's Avatar
Spectralock haze
I was helping out a realtive with his bathroom project Thanksgiving weekend. I laid a field of diagonal 12" tile in the 30 sqft room, leaving him with the grouting, which he didn't appear to have any fear of. He picked up spectralok and apparently was overconfident of his ability.
Visiting on Christmas, I found that he had a visible spectrlock haze from a lack of good grout cleanup. He is a nice guy and generously gives me credit for helping him, but of course the finishing is less than desirable. What's the best way to get rid of the haze without replaceing the Porcelin tile?
TIA,
Christopher
-Christopher is offline   Reply With Quote
Unread 01-03-2010, 07:58 PM   #2
Brian in San Diego
Brian in San Diego's Avatar
First attempt would be white vinegar and water (50/50) and a white nylon pad. If that didn't budge it I think I would try some CLR and white nylon pad. (Make sure you thoroughly rinse both products off the tile once you are done.)
Unread 01-03-2010, 08:08 PM   #3
I was told by Laticrete a while ago to use the Soft Scrub with Bleach in it if the cleaning packets weren't enough..
worked like a charm with a doodle pad, on bigger floors I use an orbital buffer with a cloth pad.
whips through it real fast and comes up super clean.
^^Check out our Blog^^
Unread 01-03-2010, 08:19 PM   #4
hbrothberg
hbrothberg's Avatar
Epoxy Grout Haze Removal
While it is good to hear that our SpectraLOCK grout was used .....
..... it is not so good to hear that excess "haze" was left on the surface of the tiles for several weeks....!
Whoops ....!
The posts above have good advice regarding cleaning / removing the haze.
I have attached a Laticrete Technical Data Sheet on the subject of Epoxy Grout Haze Removal.
Henry
Henry Rothberg
hbrothberg@laticrete.com
www.laticrete.com
Office: (203) 393-0010 ext 202
Cell: (203) 988-1814
Full Disclosure: I am a 2nd generation Laticrete guy !
Follow my Blog: www.laticrete.blogspot.com
hbrothberg is offline   Reply With Quote
Unread 01-03-2010, 09:03 PM   #5
-Christopher
Thanks for the response... I'll see what I can do with it. I have to say that even with the mishap, the grout is uniform and looks great.
Christopher
Unread 01-03-2010, 10:32 PM   #6
Very handy timing. My first spectralock install is tomorrow. I'll pack the orbital just in case.
Spectralock Haze jmmcgorman Tile Forum/Advice Board 4 01-29-2011 04:46 PM
Spectralock PRO + Spectralock original Malaxi Tile Forum/Advice Board 11 01-08-2011 10:45 PM
Difference between SpectraLOCK & SpectraLOCK Pro? Jim Herold Tile Forum/Advice Board 14 09-12-2009 11:02 PM
Difference between SpectraLOCK & SpectraLOCK Pro Slurpbug Tile Forum/Advice Board 13 02-01-2008 10:54 PM
Cleaning Spectralock haze FAL28 Cleaning, Restoration and Sealing 1 06-06-2006 09:05 AM
