Unread 09-18-2009, 12:31 PM   #16
Not trying to get into an argument with the folks at Schluter or Dobri, but your situation is kinda outside the norm. 1/2" subfloor is not sufficient on it's own, and is not quite thick enough for screws (or nails) to hold without stripping. The 3/4" plywood may be stiff enough to prevent the screws from pulling it down flush with the old subfloor. Given that 3/4" plywood is sufficiently thick for a porcelain tile installation all by itself, it seems that if you fasten it to the joists, with no regard to the 1/2" plywood being there other than using longer deck screws, your floor would meet Schluter's standards. I see no down side to this method.
Unread 09-18-2009, 06:35 PM   #17
Dobri
Dobri's Avatar
Rob, i think Bob answer your question. It's up to you.
Dobri
Dobri is offline   Reply With Quote
Unread 09-18-2009, 07:21 PM   #18
UCbandit22
Thank you all for the suggestions....I will probably try to screw the 3/4 down on the joists and add the Ditra from there. The one thing that I never mentioned is that 3/4 of the whole downstairs of my house is tile and all of it has a 1/2 sub and 1/2 ply on top of that. I just bought the house last year but none of the tile is cracked or coming up, it' sjust outdated. So i will probably be okay..hopefully....
Thanks again everyone!
Rob
UCbandit22 is offline   Reply With Quote
Subfloor Question harddy Tile Forum/Advice Board 25 11-26-2008 07:09 PM
Subfloor Question HAkins Tile Forum/Advice Board 4 02-23-2007 12:13 PM
Subfloor question Raymondo Professionals' Hangout 7 12-16-2006 11:44 AM
Transistion question and subfloor question KurtH Tile Forum/Advice Board 4 11-17-2005 11:07 AM
No Subfloor Question emptysea Tile Forum/Advice Board 4 11-06-2003 08:17 PM
