Unread 04-06-2009, 06:33 PM   #1
L Ray
Ceramic Countertop Self Edge Bond Strength
Is there a standard or easy method to test the bond strength on self edge?
L Ray is offline   Reply With Quote
Unread 04-06-2009, 07:10 PM   #2
please explain in more detail what you are referring to.
^^Check out our Blog^^
Unread 04-07-2009, 09:18 PM   #3
L Ray
Self Edge bond
To clarify my question, I am looking for a reasonable test method to determine if a ceramic self edge is bonded to the backerboard without pulling it all off, there is currently no failure but the contractor has pulled some off and says some of the pieces he pulled off come off too easy. I know there is a tensile test, but in doing that, it damages the tile that is being tested.
Unread 04-08-2009, 04:49 AM   #4
There is a standard shear test, and it damages the tile and/or backerboard. It isn't done in the field, but is used to qualify a product (thinset) for use.
The contractor should not have been able to pull a piece of tile off the substrate with only his hands, if the thinset had enough time to cure. So, it looks like we still need more information here. What thinset was used, how was it mixed and applied, how long did it cure, what kind of tile, how did it look when he pulled it off, did the thinset stick to the backerboard or tile or both, etc?
Unread 04-08-2009, 05:50 AM   #5
Hammy
Hammy's Avatar
was it thinset or MASTIC? Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Countertop edge tom.m Tile Forum/Advice Board 3 06-15-2008 09:50 PM
bonding stick strength of Versa Bond and Kerdi AnthonyD Tile Forum/Advice Board 2 03-20-2007 08:57 PM
Kerdi for countertop? Vanity strength? rmcel123 Tile Forum/Advice Board 11 08-12-2006 05:40 PM
Countertop edge? cjs Tile Forum/Advice Board 7 11-22-2004 09:12 AM
Subfloor strength questions...how strong is strong enough? (for ceramic tile) BoiseXJ Tile Forum/Advice Board 48 01-31-2002 10:43 PM
