Unread 03-04-2009, 02:20 PM   #1
v10ford99
kerdi and speed set
Just a quick question Can you use speed set over ditra on the floor and kerdi on the walls or would there be problems. I might need to set and gout the same day and walk on it with in 6hrs. restaurant repair got to love the smell.
Alex
R.H. TILE & STONE
v10ford99 is offline   Reply With Quote
Unread 03-04-2009, 04:11 PM   #2
K_Tile
Member of Million SF Club!!
No problems. Make sure the speedset is pretty wet under the kerdi.
Unread 03-04-2009, 06:28 PM   #3
TGR
I asked this same question to the Schluter tec line once and they said NO if the rapid has polymers in it. Don’t know of a rapid or speed set that does not have polymers in it. I asked a Schluter sales rep if rapid was OK and he said yes. I asked a mortar expert if rapid with Schluter was OK and he said yes. I guess you can use rapid but I believe the official position of Schluter is no. I can’t believe Schluter doesn’t have a list of approved polymer modified mortars rapid or not.
TGR is offline   Reply With Quote
Unread 03-04-2009, 09:21 PM   #4
Mountain Tile
Pashley Tile
I have used speed set on Ditra many times, including exterior installs, and not a problem yet. I asked a shluter rep about it and he said yes, however, it will take twice as long to set up. If it would normally set in 2 hrs. it might take 4 hrs. Haven't had the need to use it on Kerdi, but don't see why it won't work.
Chuck
wwwpashleytile.com
Mountain Tile is offline   Reply With Quote
Unread 03-04-2009, 10:18 PM   #5
duneslider
Utah Tile Contractor
My understanding was as Chuck said. It will take longer to set but works just fine. All the schluter people I have talked to have said it is okay to use rapidset.
Bryan
EX Tile Contractor
Positive Tile and Stone
Salt Lake City, Utah
duneslider is offline   Reply With Quote
Unread 03-05-2009, 05:59 AM   #6
John K
Same here. Talk with Schluter about using it on a shower floor. They said no problem, but still give it plenty of cure time before showering in there. I forgot, maybe 48hrs, dunno.
John
www.precisiontilestone.com
John K is offline   Reply With Quote
Unread 03-05-2009, 07:18 AM   #7
I've used speed set on Kerdi shower floors. Works fine. I don't see any need to use it behind the Kerdi on the walls, though.
Bostik Kerdi-Set or Ditra-set tilenovice Tile Forum/Advice Board 1 04-25-2007 09:52 AM
Speed set Mike Finley Professionals' Hangout 13 02-17-2007 12:21 AM
Speed set over Ditra? Gaylerob Professionals' Hangout 25 11-11-2006 12:42 PM
ceiling tile and speed set superdave Professionals' Hangout 6 04-20-2005 08:35 PM
extending speed set pot life mitch Professionals' Hangout 29 03-14-2004 12:12 PM
