Welcome, Richard. Again, please go to the UserCP, find Edit Signature and enter the first name there. Some of the older members have trouble remembering a few thousand first names, eh?
but in this case my GC felt that having a seam held together by thinset was not reliable so he wanted me to turn up the membrane corners in the pan 2" up the wall so that there wouldnt be a seam on the pan floor. I could see his point. Why have a seam in such a crucial area if you dont need one?
Any correct method of installing the Kerdi on the floor will not result in a seam at the wall/floor junction. The "seam" will always be at least two inches from that junction.
I, too, tried turning the floor piece up the walls for my overlap there, but only once. Big PITA, that. I now use Kerdi Band and the pre-formed inside corners all around the floor/wall junction and then cut my floor piece to closely fit the floor only. I always have my wall Kerdi already installed (and usually tiled) before I ever get to the floor, so it all works our well for me.
And unless its really convenient to fold a sheet around a corner, I generally use the Kerdi Band in the vertical corners as well, and cut the wall pieces to fit closely to the adjacent wall.
It's a little more expensive that way, perhaps (Kerdi Band being more costly than the Kerdi sheets), but I find it makes life much easier when working alone.
