Unread 10-26-2005, 06:42 AM   #1
Rhode Island Flooring
Bill
Rhode Island Flooring's Avatar
Send a message via AIM to Rhode Island Flooring Send a message via MSN to Rhode Island Flooring
mortar question.
tile over tile, kerabond kerralastic or ultra contact? the store has some new laticrete product too but i like my choice. the tile on tha floor is ok for application. and im using dal tile hexagons with the little diamond on 12 x12 sheets. that would reccomend contact right?
Rhode Island Flooring is offline   Reply With Quote
Unread 10-26-2005, 07:32 AM   #2
chukar8
chukar8's Avatar
Shouldn't you be in the pro hangout Bill???????Ive seen youre posts here before????????
Bryan
chukar8 is offline   Reply With Quote
Unread 10-26-2005, 08:04 AM   #3
Looked like a Hangout question to me, too.
Unread 10-26-2005, 08:08 AM   #4
Rob Z
Guest
Posts: n/a
Bill
I am told that the keralastic is similar to Laticrete 333, which is an excellant product for tile over tile. Just be sure to clean the existing tile with something like Aqua Mix heavy duty tile and grout cleaner before setting the new tile.
Unread 10-26-2005, 08:54 AM   #5
Bill
pro hangout? what goes on there?
Unread 10-26-2005, 03:55 PM   #6
chukar8
chukar8's Avatar
See how much happier you are now since CX moved you to the pro hangout,lol
Wouldn't you want to use an unmodified between 2 impervious layers?????or not????
Bryan
Unread 10-26-2005, 04:12 PM   #7
Bryan, the first order of business is getting it to stick to the old tile. Need a modified.
Unread 10-26-2005, 04:16 PM   #8
chukar8
chukar8's Avatar
ooooooo ,I thought that a modified would require way too much cure time for its strength??????Kinda the same theory for between ditra and tile????
Bryan
Unread 10-26-2005, 06:16 PM   #9
scott anthony
Tile Man -- Central Florida
scott anthony's Avatar
Bryan I did call Mapei on this same issue, tile on tile. They told me Kerlastic Kerply. I'm sure the others have thier own added latex and are nearly the same BUT, I was moving a fridg that next day and broke a tile, an enormous fridge. When I pulled that tile up the mortar/latex seemd fresh as the day I put it down. If formula requires air to cure then backbuttering leaves a neverending cure which I did on most of them. Several of them sounded hollow the next day and after pulling the one tile I knew why. Anyway that's my experience with this situation, I'm not sure I will ever use it again. I would do an acid wash and go with a good modified and be done with it. But I would only do tile on tile I there was no way out.
scott anthony is offline   Reply With Quote
Unread 10-26-2005, 06:20 PM   #10
N.S. Tiler
We are currently doing a 4000 sqft job over tile that we had originally did (new owner.... they ripped out a lot of walls and made it all one area). The tiles were quite shiny smooth so we give them a good scuff with our cup grinder and we used Tec Superflex. I took up a tile after a few days to check how well they were bonded..... let's just say very well.
N.S. Tiler is offline   Reply With Quote
Unread 10-27-2005, 12:45 PM   #11
Bill
well im going over ceramic with mats 12X12 octagon with lil diamond inlays so im only going to use a 1/8 V notch this is a store job not mine so maby I should say the ol tile must be removed.
Unread 10-27-2005, 05:54 PM   #12
scott anthony
It if could it should. Now you are going to be the one who removes it though I have 700 coming out next week and through the wise advice of my friends here I am subbing this out. This guy has a lawnmower looking blade scraper thing and he says he will get the tile off and the surface down to where it was at the start. I'll get picks in on this with a new topic though. I hope this guy don't let me down.
