Unread 12-15-2018, 10:08 AM   #1
z56o2
Layout suggestions requested (see pics)
Good morning. Lurking on this forum has gotten me through to the homestretch of this bath/shower remodel I'm working on. This may seem trivial but I'm hoping someone with more knowledge/experience with aesthetics can give me advice. Please see linked pictures.
I'm doing brick layout with alternating rows, 12x12 then 12x6. I have a shelf across one of the walls that starts at the bottom of a 12x12 row. I restarted the pattern at the top of the shelf to match back up to the top of the 12x12 rows on the adjacent walls but I'm not sure how I want to do the vertical face and the 45 degree face of the shelf. Should I stack these without brick pattern or should I offset with the brick pattern twice and be back in line? Does that make sense? Initially I was planning to offset twice but the more I think about it the more I worry that it'll look like I just have a 3 collapsed rows as opposed to one taller 12" row.
Thank you in advance.
Eric
z56o2 is offline   Reply With Quote
Unread 12-15-2018, 10:32 AM   #2
Welcome aboard, Eric.
Your link doesn't work for me. We much prefer that you load your picture directly to the forum. That way they'll always be here, and they can be looked at when reading you thread.
Unread 12-15-2018, 07:40 PM   #3
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
My eyes would tell me to align joints on vertical and angled face below shelf with the narrow row above so it looks like adjacent course, only with a bump out.
I sometimes sketch something like this just to see both options. SketchUp is the tool of choice.
Peter
Unread 12-15-2018, 09:43 PM   #4
Just In Tile LLC
Just In Tile LLC's Avatar
Eric I would line up the bottom like your top piece connects with it, since your angle stops at the bottom joint of your 12x12 I'd basically continue that pattern, in theory like the shelf isn't there.
So it will be "straight". Since you have to have a joint running through the middle as well because of the angle change, I'd make that joint (horizontal one) as small as possible "16th" to give the illusion that the tile folds around the angle.
Points for using the same tile on each angle change so the pattern (if any) carries through the fold.
Justin
Unread 12-16-2018, 07:06 AM   #5
z56o2
Makes sense to me. I like the idea of using a smaller grout joint there, I hadn't thought of that. I'll post a pic when it's up. Thanks a lot.
Eric
Unread 12-16-2018, 09:44 AM   #6
Another vote to do it like Justin explained.
Unread 12-16-2018, 10:01 AM   #7
Yep, make it look like one piece as though the obstruction wasn't there.
Unread 12-19-2018, 09:51 AM   #8
z56o2
In-line with a small grout line for the "fold" turned out great. Thanks for the input everyone.
Eric
Unread 12-19-2018, 07:22 PM   #9
Looks great.
Layout Advice Requested Yogi_Bear_79 Tile Forum/Advice Board 30 03-08-2012 01:39 PM
Layout Advice Requested Yogi_Bear_79 Tile Forum/Advice Board 17 03-01-2012 10:20 AM
Tile layout suggestions? Microburst Tile Forum/Advice Board 5 05-03-2008 12:27 PM
tile layout suggestions RedRock Tile Forum/Advice Board 5 07-19-2007 07:48 AM
Tile layout design - opinions requested! DIYOHMY Tile Forum/Advice Board 7 02-15-2005 11:39 PM
