Unread 05-11-2016, 09:45 AM   #31
Originally Posted by Rob
The whole floor has some small dents all around I think from when I drizzled the water on the mud.
Not sure why a fella would wanna do that, but don't do it again.
If you have enough problems to require extensive repair, or even not so extensive repair, I recommend you tear out what you've got and try again, without the plastic dividers this time. Deck mud is dirt cheap and you'll benefit from the practice when it comes time to do the final mud bed, which really does need to be done correctly.
Unread 05-11-2016, 10:34 AM   #32
rjwz2
How hard do you think it would be to break up and remove the mud?
Rob
rjwz2 is offline   Reply With Quote
Unread 05-11-2016, 10:35 AM   #33
rjwz2
I read that I supposed to drizzle water all over the mud. Should I not do that then?
Rob
Unread 05-11-2016, 12:13 PM   #34
dhagin
It'll break up easy. Just lift a corner and hit the elevated area with a hammer. Might need a heavy hammer.
dana
Unread 05-12-2016, 08:38 PM   #35
rjwz2
Is it okay or a no no to use mortar cement for the mud? The reason I ask is because I need more cement and I got a whole bag of ultra mortar from a previous project.
Rob
Unread 05-12-2016, 10:01 PM   #36
You want nothing but sand and Portland cement for your deck mud. I don't know what you might be calling "ultra mortar," but it probably contains a good bit of lime, which you do not want nor need.
Unread 05-12-2016, 10:59 PM   #37
What CX said. That sounds like it may be a type of masonry cement. Don't use it, find some portland.
Unread 05-12-2016, 11:46 PM   #38
rjwz2
Ok, got it. I used the Portland for the first batch. Thought I'd give it a try since I had some. Thanks guys!
Rob
Unread 05-13-2016, 04:45 PM   #39
rjwz2
How long do I need to let my pre-slope set before I can install my membrane and do the top mud?
thanks.
Rob
Unread 05-13-2016, 04:56 PM   #40
Overnight is usually long enough. 24 hours is better.
Unread 05-17-2016, 01:31 AM   #41
rjwz2
What is the easiest way to cut a 1" strip off a piece of 1/2" hardiebacker? I know to score and snap larger pieces but I need pieces 35" wide and my sheets are 36". I would like to not make too much dust if possible?
Rob
Unread 05-17-2016, 01:55 PM   #42
dhagin
1. Turn the boards the other way, as 1" wide piece is a pain to work with and will need to be predrilled, mudded & taped.
2. http://www.pactool.us/snappershear/
3. Use a grinder and hold a shop vac or 2 next to the blade to capture the dust.
dana
Unread 05-17-2016, 03:11 PM   #43
rjwz2
Dana, the 1" piece will be discarded. My 3x5 sheets vertically will fit nicely with the least amount of cuts. That is why I don't want to install horizontally.
Thanks for the response.
Rob
Unread 05-17-2016, 05:45 PM   #44
dhagin
dana
Unread 05-18-2016, 11:16 AM   #45
rjwz2
Any other suggestions?
Rob
Bathroom renovation mmullen Tile Forum/Advice Board 67 04-03-2014 05:52 PM
Bathroom Renovation MelodyJoy Tile Forum/Advice Board 12 09-17-2013 09:27 PM
New Bathroom Renovation Rob13 Tile Forum/Advice Board 48 11-01-2010 06:00 AM
New bathroom renovation bpress5423 Cleaning, Restoration and Sealing 2 07-26-2009 03:21 PM
Bathroom renovation themaniac Tile Forum/Advice Board 2 08-23-2007 04:48 PM
