Unread 05-06-2016, 01:38 PM   #16
dhagin
Versabond will work fine for both the walls & floor if over Redgard.
dana
Unread 05-06-2016, 05:07 PM   #17
rjwz2
Thanks Dana. BTW, I'm on the Big Island!
Rob
rjwz2 is offline   Reply With Quote
Unread 05-08-2016, 11:20 PM   #18
rjwz2
Dana, I actually have Flexbond if it makes any difference.
Rob
Unread 05-09-2016, 05:36 AM   #19
The Flexbond will also work.
Unread 05-09-2016, 11:34 AM   #20
rjwz2
Thanks Davy.
Another question. I just finished doing my first mud pre-slope and I'm going to install my membrane. What should I plug the drain with to do the leakage test? Also, when I put the final 1 1/2" thick layer of mud on the membrane what is a good way to make sure I have a consistent thickness of material?
thanks.
Rob
Unread 05-09-2016, 12:43 PM   #21
You mark a level line around your perimeter and set your drain at one tile and and one bonding mortar thickness above the 1 1/2" thick level and screed your mud from the perimeter line to the point below the top of the drain. Frequently helpful to notch one of your screed sticks the amount of the tile and mortar thickness so you can use that to screed accurately to the top of the drain. Davy has a good photo of the notched stick, which hopefully he'll post.
Unread 05-09-2016, 06:04 PM   #22
rjwz2
Thanks CX.
Davy, I would like to see a pic of your screed stick and how you used it.
Rob
Unread 05-09-2016, 10:01 PM   #23
Davy's screed stick.
Name:  Notched Screed Stick Davy.jpg
Unread 05-09-2016, 10:30 PM   #24
dhagin
Your island may be big, but we got more people! Oh darn.
dana
Unread 05-09-2016, 10:40 PM   #25
rjwz2
Thanks CX.
I may have a problem! I just checked my pre slope that I set yesterday and there is a lot of loose sand on the surface. Is it supposed to be like that? I'm wondering if I made my mud too dry. I followed the directions I've seen in the liberry and went with a 5 to 1 ratio. Is it supposed to be like that and I just sweep off the extra sand or do I need to do something to correct it?
Rob
Unread 05-09-2016, 10:50 PM   #26
dhagin
Vacuum away any loose sand. If it just on the surface or leaves a few small voids, then thinset will take care of it as you go. If, on the other hand, you can vacuum away larger areas of the mud, then you may be looking at a re-do. Let us know how you do and post photos if necessary.
dana
Unread 05-09-2016, 10:59 PM   #27
Packing the mud down with a wood float before screeding it, then finishing with a steel trowel at the end usually takes care of that problem.
Unread 05-10-2016, 08:53 PM   #28
rjwz2
Okay, this is what I got. I vacuumed and dug out any loose concrete. I think I didn't do a good job of tamping down. So now I got some areas that I could dig up. The rest of the areas are solid except for a few areas. Is this salvageable? I'm sure hoping there is a way to fix this by adding on a layer or something as this is the pre-slope without the liner yet.
Help!
Rob
Unread 05-10-2016, 09:22 PM   #29
I think that's usually because of not sufficiently packing your mud before you screed it flat. On a pre-slope you can probably patch that with some deck mud with some thinset mortar as a bonding agent.
And having those plastic strips in there is not at all a good idea and I sincerely hope you'll eliminate such material in the final mud bed. In the pre-slope they may not be too harmful, but in the final mud bed you really don't want any plastic dividers to tell your mud and your tile where to crack.
Unread 05-10-2016, 11:17 PM   #30
rjwz2
Thanks CX for the quick response! I appreciate it. I will definitely not use the plastic in the final bed. I thought it would make the pre slope easier but now I know.
The whole floor has some small dents all around I think from when I drizzled the water on the mud. Shall I do a skim coat to make it smoother? I'm worrying about damaging the liner.
Thanks.
Rob
Bathroom renovation mmullen Tile Forum/Advice Board 67 04-03-2014 05:52 PM
Bathroom Renovation MelodyJoy Tile Forum/Advice Board 12 09-17-2013 09:27 PM
New Bathroom Renovation Rob13 Tile Forum/Advice Board 48 11-01-2010 06:00 AM
New bathroom renovation bpress5423 Cleaning, Restoration and Sealing 2 07-26-2009 03:21 PM
Bathroom renovation themaniac Tile Forum/Advice Board 2 08-23-2007 04:48 PM
