Unread 05-06-2014, 06:51 PM   #1
btw574
Friend showers being done
Took a picture of a shower beeing done at my friends house. He is having two done and they have already started tiling one of them and it is the same. None of the joints between the backer board were thinset and neither were the corners. They put mesh tape on the joints and then redgard. Most of the corners look like this and this on you can see the framing because the gap is about 3/8". I told him to have them stop as all the joints should have been filled
with thinset and mesh tape and that he will end up with a leak. This is a large bath and kitchen place doing the remodel.
He did not believe me but if I can get some advice to show him before they finish.
btw574 is offline   Reply With Quote
Unread 05-06-2014, 07:14 PM   #2
Brian,
You can get the information straight from the manufacturers web site
Click here You can jump all the way to page 4
Unread 05-06-2014, 07:44 PM   #3
Oebur
Sean
I don't see an awful lot of screws on those boards either. Check the specs for the spacing on those as well so he can present it to the installers. Might be best for him to just skip straight to the owners if it's a larger company though.
Sean
"Homer, I don't mind if you pee in the shower, but only if your taking a shower!!"
Oebur is offline   Reply With Quote
Unread 05-06-2014, 08:02 PM   #4
they also specify which fasteners can be used. (NO drywall screws)
Unread 05-06-2014, 08:18 PM   #5
evan1968
Not So Senior Contributor
evan1968's Avatar
Besides not reading simple installation instructions, they need to put on a few more coats of RedGuard. Not even close to enough. Shouldn't be able to read the printing on the board.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 05-06-2014, 08:45 PM   #6
YEah, I was going to say, that didn't look like enough RedGard on the walls. To be certain, you need to use a wet film gauge to verify the proper thickness of each coat (and it requires more than one!). It is crucial to get the proper thickness and to prepare the subsurface properly.
Lots of things wrong there...good catch. It's really sorry that supposed pros can't or won't follow manufacturer's instructions or think they know better than the people that make the stuff and provide a warranty.
The TCNA says 75% of the tiled showers built in the USA do not meet standards, and it's people like this that keep that average so high. Done right, one can work reliably for as long as you care to keep it around because of the style.
I have this friend... ses_mjs Tile Forum/Advice Board 6 07-12-2010 09:40 PM
Friend Needs Help Cheech Tile Forum/Advice Board 8 03-07-2008 06:51 PM
Help for a friend BobbieB Tile Forum/Advice Board 9 08-18-2005 05:22 PM
