Unread 06-21-2015, 07:32 PM   #1
jzucosky
Leveling a concrete floor
We are in the process of enclosing a screened in porch. The concrete floor had pavers over it and was pitched to the center to go to a drain. I've removed the pavers and the floor is in good shape. The room is now enclosed and is ready for a floor covering. The drain is removed and I would like to have the floor flat and level. The room is 20 x 16 and needs to be built up about 1 1/2" on the sides and about 3" in the middle. Self leveling underlayment seems the way to go but it seems like this amount wouldn't be a diy job. Who would I call to get an estimate? The game plan is ditra over the underlayment then some kind of tile. If anyone has any different suggestions please let me know.
jack
jzucosky is offline   Reply With Quote
Unread 06-21-2015, 08:01 PM   #2
Brad Denny
CTEF Director
Brad Denny's Avatar
Jack,
It would be less expensive to use a mortar bed. In this case, I'd try to bring it within a tolerance of about an inch, let it dry, then use an unbonded reinforced mortar bed. Do a little searching and you'll get lots of details.
Brad
Brad Denny is offline   Reply With Quote
Unread 06-21-2015, 08:48 PM   #3
Welcome back, Jack.
What Brad said, except, keep in mind that the minimum thickness for the reinforced mud bed is 1 1/4 inches.
Unread 06-21-2015, 09:41 PM   #4
I'd mud it once, the whole thickness needed and bond it to the slab with thinset. Then apply a paint on membrane over the whole thing after it sets a few days.
Unread 07-28-2015, 08:10 AM   #5
jzucosky
slate tile
I am going to be setting ungauged slate tile. It is going over laticrete spectra mat which has been thinsetted down to a concrete sub base. The tiles are 3/8" thick for the most part, some are a little thinner. Should I use a medium bed setting material or regular modified thin set? I am going to be using the mlt tile leveling system.
jack
Unread 07-28-2015, 10:50 AM   #6
Is this your screened porch project, Jack?
How flat did you make the final floor to be tiled?
A LHT (Large & Heavy Tile) mortar might be helpful if the gauging is particularly poor on your slate, but you may also be able to use a standard thinset mortar.
Unread 07-28-2015, 11:34 AM   #7
916tile
TileCoach
916tile's Avatar
How big are the tiles? 12x12 regular thinset is probably ok.
Anything bigger I would go medium bed with a 1/2x1/2 notch.
Isaac Ostrom
Northern California
www.youtube.com/916tile
916tile is offline   Reply With Quote
Unread 07-28-2015, 02:31 PM   #8
Premier Designs
Custom makes a Marble and Granite that is a medium bed, I use it almost exclusively, it's good and sticky ..
www.premierdesigns4u.com
Premier Designs is offline   Reply With Quote
Unread 07-28-2015, 03:31 PM   #9
jzucosky
Yes it's the screened porch. The floor is now dead flat. I'm setting 16 x 16 and 8 x 8 tiles in a pinwheel design.
jack
Unread 07-28-2015, 04:12 PM   #10
Laticrete 4XLT will be a great alternative
Be ready for a hair pulling experience with those un-gauged tiles. The cuss jar will be overflowing.
You have our deepest sympathies.
Unread 07-28-2015, 05:03 PM   #11
jzucosky
Smile
My wifes got her earplugs ready.
jack
Unread 07-28-2015, 06:52 PM   #12
Ron
Tile Contractor
Keep a 1-1/2" wide worn out wood chisel nearby. As you are setting the slate tile in mortar, if you have a particularly thicker surface here and there due to the natural cleft, just lay the chisel flat on the other tile holding the handle loosely with your fingers and give it a tap with a hammer to knock off the high spot. There, you will have a cleft surface again without "lippage". So easy to do. Looks much better. I used to do that all the time with the rougher Chinese and Indian slates and quartzites. Not with pretty Vermont or Brazilian slates though.
Seems no one is selecting slate anymore around here.
Ron
Terra Firma Tile
Ron is offline   Reply With Quote
Unread 07-28-2015, 06:57 PM   #13
Ron
Tile Contractor
I'd like to recommend my favourite sealer for this type of stone tile... if'n you wanna enhance the colours:
Miracle Sealants Enhance & Seal
http://miraclesealants.com/index.php...d=9&Itemid=178
Ron
Terra Firma Tile
Unread 07-29-2015, 04:42 PM   #14
916tile
TileCoach
916tile's Avatar
What Ron said
We usually set the tile and the next day go around a cleave off the irregular high spots.
We lay a margin trowl flat on the lower tile, hit the bottom of the handle and it will pop the high spot off.
Isaac Ostrom
Northern California
Unread 02-20-2016, 10:16 PM   #15
jzucosky
Size:  46.2 KBI realized I never posted pictures of the final project. Most of the tiles were an 1/8 to 1/4" out of square and varied in thickness. Needless to say I didn't get too many square feet set each weekend. If somebody is thinking about laying Indian slate, be prepared to get very frustrated.
jack
Reseal slate tile, but not sure if really slate or just tile with slate look? tazraj Cleaning, Restoration and Sealing 2 04-18-2011 01:29 PM
Adding slate to an existing slate walkway BekahLeigh Tile Forum/Advice Board 4 03-23-2009 09:59 AM
Slate and slate look-a-likes question for my bathroom rob.walstrom Tile Forum/Advice Board 7 08-21-2007 02:24 PM
Need slate estimator for 3 slate sizes in an Ashler Random Pattern carlybaby Tile Forum/Advice Board 1 07-30-2007 08:12 PM
Slate v/s Slate Tile for outdoor walkway cdbolick Tile Forum/Advice Board 6 05-03-2006 07:48 PM
