Unread 12-23-2011, 10:46 PM   #1
-Christopher
-Christopher's Avatar
Basement Shower - First Kerdi
May as well start this... I always welcome advice.
Beginning a 3'x4' basement shower, mud pan w/Kerdi Drain, etc.
First question... Which beer goes best with deck mud and chipped concrete?
-Christopher
Christopher
-Christopher is offline   Reply With Quote
Unread 12-24-2011, 12:22 AM   #2
cwilde72
cwilde72's Avatar
Sam Adams while you do the work then treat yourself to a Stella when the work is all done
Chad Wilde
Precision Tile
Huron, SD
cwilde72 is offline   Reply With Quote
Unread 12-24-2011, 11:41 AM   #3
Make sure it's non-modified variety before you drink it.
Unread 12-24-2011, 11:53 AM   #4
Chugiak
Forgotten more than I now know
I dunno, a 8066095615 fortified with a citric agent is a proven application.
Earle
DIY Ordinaire
Chugiak is offline   Reply With Quote
Unread 12-24-2011, 04:47 PM   #5
Just don't fall into the "light beer" trap. Get a full bodied brewskie, and you'll be fine.
Unread 12-24-2011, 11:49 PM   #6
muskymike
muskymike's Avatar
Grab some Buds.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 12-25-2011, 12:22 PM   #7
-Christopher
Ditra under a shower pan?
I may have to rotate through the brands to see what works best.. I'm starting with Sam Adams... Winterfest....
1st question.. The bathroom is in the basement and 2 concrete fllor slabs meet, splitting the bathroom down the middle,including the edge of the shower (not easy to see in the picture after the plumbing was concreted over). Should I run ditra under everything to isolate the showerpan and floor tile field from possible movement?
Christopher
Unread 12-25-2011, 12:41 PM   #8
Welcome, Christopher.
If you have a construction/expansion joint between two slabs you're going to need to honor it all the way through your tile surface if you really want to protect the tile installation.
Ditra is not a crack isolation membrane, but even if it were the above would still apply. Indeed, the manufacturer of Ditra requires that the membrane even be separated over such joints.
For your Kerdi shower, I think your best option is to lay down a cleavage membrane and a mud bed at least 1 1/4" thick at its thinnest point with welded metal mesh in the vertical center. That won't really meet any industry standard over such a joint, but I think it'll give you more protection than any other option.
And you'll want to be sure you use a flexible sealant at your tile floor/wall joint in there. And cross your fingers, of course.
My opinion; worth price charge.
Unread 12-25-2011, 12:56 PM   #9
-Christopher
Im goin to need more beer...
Do you have a preferred clevage membrane to recommend?
Christopher
Unread 12-25-2011, 12:58 PM   #10
Whatever is handy, cheap, and works. If we don't remember to bring a section of tar paper, we use a plastic trash bag laid nice and flat
Unread 12-25-2011, 01:08 PM   #11
-Christopher
btw.. Merry Christmas!
Christopher
Kerdi shower in Basement Clarification regulartom Tile Forum/Advice Board 11 01-16-2012 08:38 AM
Kerdi membrane over concrete basement wall Dan Woods Tile Forum/Advice Board 10 03-14-2009 08:59 PM
Kerdi tray for a walk-in shower in basement karmapolice Tile Forum/Advice Board 6 09-14-2007 09:43 AM
Trout's Kerdi Basement Shower jefftrout Tile Forum/Advice Board 1 06-16-2006 06:22 AM
Pam's Basement Kerdi Shower pmcall Tile Forum/Advice Board 18 09-10-2005 04:13 PM
