Unread 11-15-2010, 08:53 AM   #16
bbcamp
The fuller you fill the grout joints, the less likely trash will collect there. However, fuller lines mean wider lines. I'd consider stopping at the top of the vertical sides of the tile. This gives the floor a nice texture. You may have to give the housekeeping staff a small raise, though.
Make a sample board with a few scaps of your travertine. Seal about half of it. Grout the whole thing and see which you like better.
You can either remove the Kerdi or texture over it. I think you would be making the drywall guy's work a little harder if you left it in place. Score the Kerdi where you want it to end, then peel the mat off the wall. It should come off fairly easily if you pull it straight from the wall. The remaining thinset and fleece can be removed by rubbing with a brick or a tile rubbing stone. Since it will be textured, you won't have to make it perfectly smooth. Let the drywall guy earn his pay.
Unread 11-15-2010, 09:25 AM   #17
oakland76
terracotta
Thanks for the quick response. Do I still use the grout float or just the grout bag if I am going to the top of the sides?
Jason
oakland76 is offline   Reply With Quote
Unread 11-15-2010, 02:24 PM   #18
bbcamp
Grout float and sponge to clean the tile faces.
Unread 12-02-2010, 09:43 PM   #19
oakland76
floor vent
Both of my projects are nearly complete thanks to the advice found on this forum but I have one final question. I have to install a floor vent through the terracotta floor tile to bring heat into the room. I have the 8 x 4 boot and decided on the placement. I have made sure the duct will not interfere with anything below the floor. My idea was to use my angle grinder to cut out the necessary tile then a jigsaw for the plywood. The floor boot has a half inch lip around it which I assume sits ontop of the tile but im not really sure. Any suggestions?
Jason
Unread 12-02-2010, 09:46 PM   #20
I suggest you post us a picher of your vent hardware including the grille.
Unread 12-02-2010, 09:57 PM   #21
oakland76
vent
The grate will not be delivered until about dec 13 so I will post a photo then.
Jason
Unread 12-26-2010, 04:30 PM   #22
oakland76
travertine vessel sink
I just installed a travertine vessel sink and water tested. The water was literally dripping out of tiny holes everywhere. How do I fix this before wy wife has a stroke? I have stone sealer but will that be enough?
Jason
Unread 12-26-2010, 05:23 PM   #23
Jason
Return the sink. Pick something else or bring a large bucket of water when you select a new one.
What dolt thought making sinks out of a porous stone was a good idea?
Unread 12-26-2010, 08:19 PM   #24
WendyHMN
Amateur Jack of All Trades
WendyHMN's Avatar
But they're so pretty.
Seriously, I would never put a stone sink somewhere it would get hard use. And that's coming from someone who bought one for my own master bath. It will be used for basic face washing and tooth brushing and that's it. We're putting in a grid drain so it will never be full of water for any time. And I plan a program of careful cleaning and sealing. Mr. Wendy really likes stone sinks so I'm totally willing to give it a try.
Wendy
Blue belt DIYer. Moderately proficient and occasionally useful.
See my finished master bath here.
WendyHMN is offline   Reply With Quote
Unread 12-26-2010, 08:47 PM   #25
oakland76
It is in a guest bath that will most likely be use for hand washing. Is regular travertine sealer good?
Jason
Unread 12-26-2010, 10:07 PM   #26
Not sure you'll convince anyone that such a thing exists, Jason.
Penetrating sealers for stone are not intended to make the stone waterproof. They do seal, for a while, against some water penetration, but their real purpose is to make the surface easier to clean and maintain.
I honestly wouldn't spend a minute trying to improve what I'm seeing as a clearly defective product. Not making a lotta sense to moi.
Unread 12-26-2010, 11:00 PM   #27
oakland76
There are little tiny holes in the epoxy, I am trying to get this done by the 30th but for the price paid I will go by the fixture store and have them get me another. Thanks for the input. By the way CX, I am still waiting for the vent boot.
Jason
Advice needed on Spacing with Tuscan Leveling System JohnWild Tile Forum/Advice Board 7 10-05-2009 01:18 PM
Leveling Concrete ? FULL FLEX Professionals' Hangout 14 03-09-2009 05:30 PM
3/8" leveling needed under Ditra - ideas? remodelboy Tile Forum/Advice Board 5 03-25-2008 11:16 AM
Renovation gone wrong, advice badly needed. Ebonfyre Tile Forum/Advice Board 12 09-07-2007 02:43 PM
off topic: help badly needed v1rtu0s1ty Tile Forum/Advice Board 39 01-16-2006 10:27 PM
