Unread 10-20-2021, 10:19 AM   #1
John W Foster
Tips For Installing Latasil
In our new outdoor kitchen, I tried to put Latasil in 54' of 3/16" expansion joint yesterday. the first section I tried was a disaster. I taped the joint well, applied the silicone and tooled it, and it looked reasonably good. I pulled the tape off as per instructions and tried to retool the joint to get rid of the feathering on the edges from pulling up the tape, that created a total mess. Does anyone have any tips /tricks/hacks ?
It was also a windy day yesterday and there was too much stuff blowing around it the air and landing on the uncured silicone, I at least learned that lesson.
John
John
John W Foster is offline   Reply With Quote
Unread 10-20-2021, 04:59 PM   #2
Tile & Stone Guild
King Of Tile
Spray it with denatured alcohol before you retool it.
Tile & Stone Guild is online now   Reply With Quote
Unread 10-20-2021, 09:14 PM   #3
Keep a bowl of water with a little Dawn dishwashing liquid in it. Dip your finger in it before tooling the silicone.
Keep some paper towels nearby to wipe your finger off after each pass.
Unread 10-23-2021, 06:12 PM   #4
Karls tile Inc
Get a spray bottle and mix dawn dish liquid with some water. Get a caulking tooling spatula . Lowes and Home depot carry them. Install the caulking and then spray the soapy solution on the caulk. Use the tool to remove the excess caulk to a perfect bead. Wipe the tool clean with paper towels. Super easy!
Karl
Karlstile.com
Looking for tips installing pencil bullnose Shady at Best Tile Forum/Advice Board 6 07-15-2017 10:56 PM
Tips for installing tile on a slanted ceiling? Ebonfyre Tile Forum/Advice Board 7 02-24-2008 10:03 PM
Need tips on installing travertine in a shower CO tiler Tile Forum/Advice Board 5 10-09-2007 10:11 AM
Installing cultured stone fireplace, tips? Alastair Tile Forum/Advice Board 13 11-30-2004 03:28 AM
Need tips on installing slate floor droopy1592 Tile Forum/Advice Board 10 06-07-2004 04:08 PM
