Unread 05-30-2019, 11:23 AM   #16
Elkski
Elkski's Avatar
Charles, that previous repair info should have been included in the initial post. However I don't think it matters. You need a new shower . I asked about plumbing in the wall. Surely water doesn't get to a shower head without plumbing.
A) I guess someone in your family takes super long showers.
B) maybe the shower head was changed and now leaks in the wall behind when it's on.
C) new shower. Get ready for 3-5 k$
Teddy
Unread 05-30-2019, 01:35 PM   #17
blueheronNC
The 2018 re-caulking work was described in my second post.
Not sure I agree that it's a plumbing leak as I wasn't detecting any moisture directly behind the shower / shower head in the closet area. The only affected external area is the bottom of the closet doorframe and baseboard that abuts against the shower curb area as moisture wicks upward. My guess is that the failure is in the curb or where the curb meets the vertical portion. This is a second floor shower and the ceiling area directly below it is absolutely dry.
That said, long showers? yes. New shower? Likely yes. Agree that the system shouldn't rely on absolutely perfect grouting and caulking to not fail as the underlying flaws remain.
After non-use for six days, everything is finally dried out.
Charles
blueheronNC is offline   Reply With Quote
Unread 05-30-2019, 02:29 PM   #18
Elkski
Elkski's Avatar
No water floor below can be because there are no holes in subfloor in that area. It's dry on the outside but wood is rotting inside the wall.
Teddy
Unread 05-30-2019, 02:40 PM   #19
You can at least prove/disprove a plumbing leak by removing the shower head, and the hose from the wall elbow of the hand held, capping them, then turning the water on.
Unread 05-30-2019, 09:40 PM   #20
Elkski
Elkski's Avatar
Capping an a leak test is a good idea. But I'm still thinking there are problems with the waterproof drainage system.
So in the past water was going under the shower track? At several grout lines? Or Just the corner?
I still wonder what % of showers I the USA are leaking?
Teddy
Unread 05-31-2019, 05:58 AM   #21
Gozo
17.41%. But that only includes the continental 48 states. I googled it.
Jeff
Unread 05-31-2019, 08:12 AM   #22
Sounds low to me, Jeff.
Anyway, how Google gonna know that?
Unread 05-31-2019, 02:16 PM   #23
Gozo
I just made it up. Seemed appropriate for the way life is this day and age. I couldn’t resist letting my sarcastic side show through.
Jeff
Unread 05-31-2019, 03:06 PM   #24
Hi, Charles.
Originally Posted by blueheronNC
...Bubba's theory about that repair potentially overzealously covering weep holes or other new conduits of moisture from the shower panel into an already compromised underlying system could certainly hold merit, but that wouldn't explain the weeping occurring in two opposite parts of the shower floor in areas that should be draining into the mud base and down the shower drain.
Could be that there are five or six things wrong with this shower...
My theory was directed for the main leak getting into the wall. It wasn’t meant to address the other problems. They might be related. But I’m not assuming anything. Like you said, there could be multiple culprits.
For the wet grout joints: Water could be getting into the tile assembly via a pinhole in the grout somewhere above the wet grout. But I also see actual cracks in the floor grout joints an water may be going in....then slowly leeching back out after showers. Do you know any reasons for the cracks?
Something I meant to ask earlier, but forgot: What’s with the different tiles in the corners? It looks like a repair was done, judging on the color difference.
Unread 08-11-2019, 11:05 AM   #25
blueheronNC
Update: ripped out the shower floor and curb tile and had the shower rebuilt. Turns out the shower pan liner only covered about 3/4 of the shower floor and none of the curb whatsoever.
No clue how something like that passed inspection.
Charles
Unread 08-11-2019, 01:15 PM   #26
Elkski
Elkski's Avatar
Sad thing is that the guy who built this shower never heard about his failure so he is probably doing it the same way today.
Teddy
Re-tiled shower has water issue iakers Tile Forum/Advice Board 8 08-05-2012 10:43 PM
Water/Mold in Shower Greenboard but no leak... gsuch Tile Forum/Advice Board 24 07-12-2011 08:25 PM
slick tile, water leak? ikey Tile Forum/Advice Board 6 05-23-2007 10:57 PM
Slate Shower Floor Water Leak cctumlin Tile Forum/Advice Board 8 07-16-2006 11:27 PM
Granite Tile - Moisture retention Jerry Smacks Tile Forum/Advice Board 2 08-13-2004 05:40 PM
